First oil change botched
Tv_fixer
Doug
'20 4Runner TRD, '21 Tacoma TRD
The question you might be thinking about is which fluid did they actually drain out??? The transmission fluid?
I did this once... I was in a hurry... doubled the oil, drained the transmission. Didnt check the oil because I knew how much to put in.... Cut our honeymoon really short... felt like a real dumbass.
Samsquantch
Nick
Crestline California
2017 Jeep Wrangler
Same here…
It’s like touching a hot stove, do it once and it’ll never happen again 🤣
I did this in my wife's brand new F150, and then we drove all the way to lake havasu from san bernardino before I realized it. Holy cow that was a huge cleanup. Never ever ever happening again 😆
robsafari
robsafari
Upstate New York
Jeep
UPDATE:
They paid for the tow 30 minutes away and said oil filter needed to be tightened. Also said the tech just never cleaned up after himself. Conveniently he is now on vacation and I'd say he needs it apparently. Boss will be waiting for him when he gets back is what he told me 😬
Engine compartment was detailed and overall it is a best case scenario considering the circumstances. I will probably not go back but I was trying to use my ford pass rewards points. Better save them for something else. Still have intermittent windshield wiper fluid spray which was a manufacturer issue but of course it's worked both times they tested. I removed the cowling and checked the line a week after I bought it but must be further down.
Thanks for the support,
Bobby bronc
da_jokker
Jeep Wrangler JKUR
Is oil pressure taken before or after the filter? Hopefully after and if your oil light never came on, you might be ok.
One thing to note is that oil leaks are a funny thing... A small oil leak can go everywhere.. you'd swear you lost quarts when it was just a little.
kodiakisland
Arkansas
Hopefully no harm done. Does this appear to be the level? If so, you might have lost maybe 1/4 quart. That doesn't seem like a lot but I can attest that small amount could look like a disaster.
Btw, that oil filter is a pain in the ass to get to. I have long arms and I have trouble reaching it if the tire is not removed. I can see it being a problem for many people.
The 2.3 oil filter is very easy for me to get to. I just reach in from the wheel well with the tire on. I can see depending on tire size and lift it would probably have to be turned in or removed, but it takes less than 5 minutes to remove and replace. And with the drip rail, not one drop of oil is spilt.
RimrockPaul
Paul
Rimrock AZ
2021 Ford F250
If it were me I would've already drained the oil out of it if I had any indication they overfilled it like you do and taken more pictures and video. Then placed a not so nice call to the dealer when they open. Do not drive it.
I think they didn't drain..just added oil.
