- First Name
- Doug
- Joined
- Jun 23, 2024
- Threads
- 34
- Messages
- 1,569
- Reaction score
- 3,724
- Location
- Washington
- Vehicle(s)
- '24 4-dr WT, '22 2-dr WT, '15 Explorer Sport, '02 F250 SD V-10
- Your Bronco Model
- Wildtrak
I agree with @AKBronc49, find the truck and deal YOU want and make it happen. Even if you get a 2.7L truck in the valve recall window, my understanding is they GENERALLY tended to go bad very quickly, like less than 10K miles, if it actually had bad valves. Plus I believe those VINs covered under the valve recall have a pretty generous extended power train warranty.
Just research the VIN and options closely as the axil/skids/final drive ratio/tire size/billion other options gets confusing across packages and model years. Later painted tops are more favorable than MIC. Personally I'd consider Sasquatch as a no brainer. I'd probably also look for the Severe Duty Steering Rack in there for the piece of mind it provides, even if you only do light off roading. Oh, if there are any open recalls *cough* be sure they are addressed or at least come to terms with them.
