Fire Extinguisher Mounted Pics - Post Em!
B Miller
Sherwood, OR
B Miller can verify, but I would think type A would cover most of your interior, as well as brush or anything else that catches fire outside the vehicle...
This is correct. The "A" in ABC covers common combustible materials, such as wood, paper, or most plastics.
We carry a 20 pound ABC dry chemical in the fire engine. On a car fire, we start with water and foam. If it's a stubborn fire we use the dry chemical.
We don't start with the dry chemical because after it's used, we have to send it out to be re charged. Most of the time water and foam does the trick.
mtap
Mervin
Cape Coral, FL
Toyota Tundra, Hummer H3, Harley Sportster
Went with a cheap mount on amazon…holes didn’t line up perfectly so I used a hose clamp wrapped with electric tape and also lined the roll bar with Velcro for the bottom …pretty solid.
You can use existing bolt for the top hole (the one that secures your MIC-same thread pattern).
Ford Bronco Fire Extinguisher Mounted Pics - Post Em! EDEC9770-536D-4EA1-B170-287502052C45
Ford Bronco Fire Extinguisher Mounted Pics - Post Em! BC58A227-23CE-4800-8151-19372BE7FC30
Ford Bronco Fire Extinguisher Mounted Pics - Post Em! D31A7DEC-2A0D-42C0-BDD3-C91005F82A4A
Ford Bronco Fire Extinguisher Mounted Pics - Post Em! D417589C-A935-4D59-9898-018C80FA702A
Ford Bronco Fire Extinguisher Mounted Pics - Post Em! 07EB03D4-05D4-4D4B-96C3-5A46A7ED02E6
Ford Bronco Fire Extinguisher Mounted Pics - Post Em! D83476F2-A3EB-4B8E-9152-57F578F30308
Ford Bronco Fire Extinguisher Mounted Pics - Post Em! B3D37CAB-EB6C-4C65-AAA3-AD1A0B665B74
Stick355
2004 Mach 1, 2020 Explorer ST, 2021 Ranger Tremor
Ford Bronco Fire Extinguisher Mounted Pics - Post Em! 44388195-0BA7-4630-B4E6-852F2713359B
Atomic Monkey Industries
Bought the one for a Ranger, they didn’t have a Bronco specific one at that time.
Jpursuit
J
Houston
2008 f250 king ranch 4wd, 2021 Bronco
I have an Element Extinguisher on the molle driver's seat panel. Was looking at regular units but just felt these were better and easier to mount and based on what I've seen they seem to work the same if not better so... that's what I went with.
Bought one of these for each vehicle as well. Thanks for posting the way you mounted it. I've been looking for a convenient yet out of the way spot for this.
SoCalG
SoCalG
Southern CA
2022 2DR Bronco BD
KDoug866
Detroit, Michigan
2022 Bronco
ChompSticks
ChompSticks
Cumming, GA
'02 E55 wagon, '98 Suzuki X-90, '96 Town Car
You made that yourself? Are you able to move the seat easily? Mine is mounted down low but I have to be careful not to push the seat all the way forward. (My seat is all the way back here, handle isn't in the way in driving position)
Ford Bronco Fire Extinguisher Mounted Pics - Post Em! 1660935265945
Tricky Dick
Dick
PNW
www.TD-Distributing.com
I've been known to do a little fabricating from time to time. I have to pull the extinguisher to slide the seat, but I've never had to do that once I got it set where I wanted.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Better said: The fire extinguisher stops others from screwing with your seat. (y)
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
We were looking at making a mount for these threaded holes. We stopped when we noticed our Badlands didn’t have those provisions but our wildtrak did.
My '21 Badlands has the bar holes!
ChompSticks
ChompSticks
Cumming, GA
Ahh poo. That would be no slice for us then. Love it though! If I were single it would be perfect!
