Fire Extinguisher Mounted Pics - Post Em!
SwampCactus
2022 4 Door Cactus Grey Badlands Sasquatch
+ 1 for the mOaR dOoR, eh @Tricky Dick? :sneaky:
I’m curious if anyones bolted anything to the rear roll bar, where those two exposed holes are. Seems like a logical spot.
Yes I have mine mounted there. Since this photo I moved it to the other side because I have a battery charging system on that side now. But this is the type of bolt you use.
Also check out my build thread. Some conversation about fire extinguishers in some of the earlier posts.
https://www.bronco6g.com/forum/threads/meet-moon.41320/
Ford Bronco Fire Extinguisher Mounted Pics - Post Em! IMG_3528
Ford Bronco Fire Extinguisher Mounted Pics - Post Em! IMG_3481
JcrOffroad
Portage, Mi
2021 Ford Bronco Badlands
My late 2021 Badlands has them (11/12/21 blend date), so it isn’t just a 2022+ thing. Maybe it was one of the undocumented Job 2 changes implemented in late 2021, when the factory rolled in the Hard Top Prep Kit for the people changing their orders from hard tops to soft tops to get quicker deliveries? 🤷‍♂️
My quick release came in so I started designing an under seat bracket to mount it to. Hope to have it wrapped up today.
Since I saw these posts back to back, I have to ask, @JcrOffroad why are the round holes not lined up with the molle grid? I like my table but this always bugs me.
It’s an every other hole setup. Honestly, it comes down to cost savings. Reducing cut time on the laser.
zuke
Stafford VA
I made a mount that puts mine right in front of the driver's seat, tied to the seat rails, But I don't have pictures of it at work, I'll try to remember to post some this evening...
The more I've thought about it, and seen talking on wheeling forums though, I think you really should have two, One like I currently have that the driver can access without having to remove seatbelts/harnesses but also one like many here on the Rollbar in the back...
The one under the seat is for you, The one in the back is for someone coming to help you or when you need to help someone else...
Tricky Dick
Dick
PNW
www.TD-Distributing.com
What I mean is why are they centered in the cross at the far left and gradually drift out of the cross as they move right?
Tricky Dick
Dick
PNW
I made a mount that put's mine right in front of the driver's seat, tied to the seat rails, But I don't have pictures of it at work, I'll try to remember to post some this evening...
I'd like to see that. I'm attaching it to the rail release handle myself.
zuke
Stafford VA
I took a piece of DOM just long enough to fit between the rails, then made some brackets and welded them to it so I could put them under the front bolts of the rails, then I bolted one of these to the DOM;
https://www.amazon.com/gp/product/B082CNTJVV
To make it a quick release.
You have to be mindful of the knob when moving the seat back ward and forward so you don't pinch your hand, but everything clears without issue...
BroncoKong Jr.
Andrew
We were looking at making a mount for these threaded holes. We stopped when we noticed our Badlands didn’t have those provisions but our wildtrak did.
My BL has those threaded holes. Believe it's a 2022+ thing.
It's a 9/1/2021+ (Job 2) thing. Mine was built that week and has one roll bar with holes and one without. :(
Considering having a shop add those hex nutserts to the other side. Ford doesn't care.
zuke
Stafford VA
Sorry, really hard to get good pics in that small dark space, Lemme know if there is anything I can clear up..
Ford Bronco Fire Extinguisher Mounted Pics - Post Em! PXL_20220504_232030295.MP
Ford Bronco Fire Extinguisher Mounted Pics - Post Em! PXL_20220504_231819249
Ford Bronco Fire Extinguisher Mounted Pics - Post Em! PXL_20220504_231943870.MP
Moto26
Tucson AZ
Ford Bronco Fire Extinguisher Mounted Pics - Post Em! 2E9AE418-F4A4-466E-A0B5-3C425598A57B
2.5 lb. Amerex ABC and Bartact mount. I like that I can just pop those two red ends of the Velcro straps and the whole thing releases instantly. The bottle can just stay in the bag while you use it.
I'm still going to get an Element to keep up front...
BroncocnorB
Paul
Clearwater Beach
1965 Cobra,
What is benefit of abc v bc extinguishers
Moto26
Tucson AZ
B Miller can verify, but I would think type A would cover most of your interior, as well as brush or anything else that catches fire outside the vehicle...
broncodeadhead
Andrew
Folsom CA
Bronco, Dodge Challenger, Nissan Pathfinder
I'm curious if your rear rubber mat has a picture on the passenger rear underside indicating a cutout spot for a fire extinguisher. My same mat for the four door has the dotted outline showing where to cut the mat to accommodate what I assume is a bracket for a fire extinguisher. I haven't seen anything from Ford dealing with a factory mount though.
Actually yes I do see that on my mat…..honestly I had not previously noticed it….but your question re a mount is a good one….maybe they are working on something…. But I’ve been happy with my JCR Molle panel mount, it’s very secure, but things are also easily removable with the quick fist attachments
BroncocnorB
Paul
Clearwater Beach
1965 Cobra,
I googled. I see that A rating would be good for interior plastics, but I think the B rating would handle plastics as well, driven by flammable liquids. Plus I think the white extinguisher looks better. But what do I know.
