Fire Extinguisher Mounted Pics - Post Em!
Last Ride Bronco
southern USA
Nissan pup
There are a lot of good ideas out there, but a picture is worth a thousand words. Show a pic of your fire extinguisher setup. Everyone needs one on board, but not everyone has thought it through. Maybe one of these pics will motivate someone to, “Git er dunn”.
Here’s a pic of someone’s Setup I saw at BSCE.
Ford Bronco Fire Extinguisher Mounted Pics - Post Em! 0AEAFFFA-2722-4F71-A3CB-F45BFF209814
Lakelife36
Ben
Interior of BC
Is there room for a small one in the storage bin under the rear floor?
Last Ride Bronco
Last Ride Bronco
southern USA
Nissan pup
I doubt it, but you need somewhat quick access to a fire extinguisher when you need it. Under the rear floor would be defeating the purpose.
SubmarineNuke
Richard
Houston, TX
twitch.tv
Bronco Wildtrak
Attached mine to the toll bar on the passenger side. Used the Bartact holder (cheaper and faster shipping via Amazon than their website)
Ford Bronco Fire Extinguisher Mounted Pics - Post Em! 38A7422F-124B-423A-9C31-7501BF18C6B0
Ford Bronco Fire Extinguisher Mounted Pics - Post Em! 444ECBAA-E66A-48F5-A89D-FD6E1357F897
Last Ride Bronco
Last Ride Bronco
southern USA
Nissan pup
These are all great solutions and would work on the roll bar of a 4 door. The 2 door however, doesn’t have the same exposed roll bar. There is not enough room. I guess that is why the bottom of the fold down table is probably the best spot for the 2 door (unless someone has gotten real creative).
Tricky Dick
Dick
PNW
www.TD-Distributing.com
I didn't even think about that, speaker is in the way. I'm thinking of hanging one off the front seat slider handle, it's never moving again anyway.
RynoRanger
Chuck
Gilbert, AZ
azbluey.com
2.7L Badlands NS 4dr
I have an Element Extinguisher on the molle driver's seat panel. Was looking at regular units but just felt these were better and easier to mount and based on what I've seen they seem to work the same if not better so... that's what I went with.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
+ 1 for the mOaR dOoR, eh @Tricky Dick? :sneaky:
I’m curious if anyones bolted anything to the rear roll bar, where those two exposed holes are. Seems like a logical spot.
Ford Bronco Fire Extinguisher Mounted Pics - Post Em! CEA4A653-78FD-489D-B3A7-2964EB12BBF0
Last Ride Bronco
Last Ride Bronco
southern USA
Nissan pup
Great idea!
broncodeadhead
Andrew
Folsom CA
Bronco, Dodge Challenger, Nissan Pathfinder
I have a two door, and I attached my fire extinguisher to the JCR rear window molle
Ford Bronco Fire Extinguisher Mounted Pics - Post Em! 9466DC76-A688-4A69-84FA-FF502F7F365D
Ford Bronco Fire Extinguisher Mounted Pics - Post Em! 14421D5A-FED5-41C0-A0D7-B50334A12FC9
panel with a quick fist attachment.
Tricky Dick
Dick
PNW
It looks like one could fit on the 2dr roll bar if you still had the hard top, or had a slimmer extinguisher.
My under seat idea looks like a go if I figure out a better mount.
Under the rear 12v socket could work too.
Ford Bronco Fire Extinguisher Mounted Pics - Post Em! PXL_20220430_221645016
Ford Bronco Fire Extinguisher Mounted Pics - Post Em! PXL_20220430_221620257
Ford Bronco Fire Extinguisher Mounted Pics - Post Em! PXL_20220430_221413738
Ftchmup
WI
23 Bronco, 20 F-250 Tremor
Ford Bronco Fire Extinguisher Mounted Pics - Post Em! 915E05DE-9781-4561-BC1F-ED9F97E96251
