Finally Frame Mounted Sliders from LOD OFFROAD!!!
Status
Not open for further replies.
Frankie945
Frank
Louisville KY
Q50
I noticed that couple weeks ago about the pinch seam being photoshopped in their photos. I got some Wurth under coating spray to blackout the seam before the install. I watched a few jk videos with people installing them to get a better idea on how they’d look and most of guys used vinyl wrap to cover the seam.
LOD Offroad
LOD Offroad
LOD Offroad
lodoffroad.com
Jeep Wrangler JLU, Jeep Gladiator, Bronco
The owner of our Bronco had tried vinyl to cover the pinch seam. I would recommend something more permanent like a rocker guard coating. The vinyl was not holding up well.
Frankie945
Frank
Louisville KY
Q50
No worries I picked up a can of Wurth High Build UnderBody UnderSeal. Same stuff a few others on here have used to cover the seam and they said they had great results with it. Looking forward to getting the sliders.
cjindna
DC
2022 Base Sasquatch 4 door 2.3l 10spd
LoD’s install instructions include the use of a spacer around the trailing arm mounts and recommend not using the spacer if you have trailing arm skids. Are you concerned that won’t work? Spacer too small compared to typical trailing arm skids?
No concerns with fitting a skid under however there were several ledge pivots where I would have hung up on the channel protruding out and away vertically from the arm mount. Certainly something that can easily be cut off but also an easy redesign of the mounting point.
Badassbronco
Georgia
Submitted for free rails
LOD Offroad
LOD Offroad
LOD Offroad
lodoffroad.com
In case anyone forgot, dont forget to send us some pics of you and your Bronco (4dr)! Our slider giveaway will be closing soon!
Status
