Graydon
2022 Ford Bronco Base 2dr
Hey guys, I just got done both cleaning and ceramic coating my fender flares because, well, they looked pretty terrible even right after washes with tons of chemical stains. I unfortunately didn’t take any close ups of just how bad they were but they came out fantastic considering!
I’ve heard you can use Scrubbing Bubbles however I just used Dawn dish soap and a sponge and scrubbed them off really well. Then I prepped them and applied Adam’s Polishes Ceramic Graphene coating. I’ve had great luck with Adam’s products in the past so I’m sure they will look good for a long time now.
I was surprised how many little rock chips there were already in only 6,000 miles. I think the rest of the Bronco is screaming for some ceramic next!
Ford Bronco Fender Flare Cleaning and Protection (How-To) -- Dawn Dish Soap, Sponge, Adam's Polishes Ceramic Graphene Coating 867F3DD5-EB29-4EBA-ADEE-206BC7252425
Ford Bronco Fender Flare Cleaning and Protection (How-To) -- Dawn Dish Soap, Sponge, Adam's Polishes Ceramic Graphene Coating 7B00CE6E-42B5-4B0F-ACFE-0C31E929460B
Ford Bronco Fender Flare Cleaning and Protection (How-To) -- Dawn Dish Soap, Sponge, Adam's Polishes Ceramic Graphene Coating 13BB8413-B81D-48AE-99E9-673F24AA1DF5
Ford Bronco Fender Flare Cleaning and Protection (How-To) -- Dawn Dish Soap, Sponge, Adam's Polishes Ceramic Graphene Coating E5613553-26F8-401B-BCC3-A78A56AE3345
BottleShark
TJ
East Texas
Nautilus, Samurai, 12v Dodge, Fiero, Karma Ghia
100% adding front fender mud flaps day one on my Bronco.
OleGreenBronco
Graydon
That is a great idea honestly. I’ve been on the fence about mud flaps for a couple weeks but I think I’m going to pick a set up soon. Even the highway tires on the base fling a TON of mud and rocks, it’s insane. I’m nervous to see how much mud terrains or all terrains are going to throw. The mud I can live with, just don’t want all the rock chips.
BottleShark
TJ
East Texas
I’ve used these on a few vehicles. They work good, get the job done and done brake the bank. I would get the Ford flaps but they don’t work with the Badlands Rock Sliders 🤷‍♂️
SUNPIE Car Mud Flaps Universal Fit Black Splash Guards (4 Pack) with 20 Pieces 6mm Fastener Rivet Clips https://a.co/d/c0SbnYg
Tdub0527
Ted
Minneapolis
'21 Bronco Badlands, 2024 Rivian R1S
Did you remove the fenders to clean and coat?
JohnZi
Piotr
British Columbia, Canada
www.instagram.com
Bronco Badlands '21
jddunfee
2021 Ranger Tremor
Good thing these are easy to replace but I'm sure at a big expense. Thanks for the info and they look great now that you cleaned them up👍
AK SNO RIDER
Ty
Alaska
I used Adam's graphene on mine as well, and 2500 miles and half a salty Alaskan winter later they still look good except where they've been beat up by flying rocks.
I expect to have to re coat the vehicle every spring, as even the best ceramics can't handle our winters
710-oil-614
Cal
Columbus, Ohio
2023 Maverick Tremor, 2010 Toyota Tacoma
Looks great! I did something similar with my fender flares and rear bumper using Cerakote (ceramic coating very similar to Adams). I'd recommend that owners Cerakote or ceramic coat (with a product of their choice) all of the black mic pastic on the exterior.
EDIT: Don't touch your MIC top with anything......because, well.....
Two tips/notes:
1. When washing your fenders, bumper, or plastic be sure to not just apply the dawn soap directly to the plastic and start scrubbing. The "power" of Dawn is activated with suds (hence their power wash formula). So either Dawn in a bucket and fill it with a hose on jet to generate the suds OR buy a foam soap dispenser (or save one from your hand wash) and fill it with 50% dawn and 50% water - boom - powerwash.
2. Once done washing the parts make sure they are absolutely dry.
Ceramic coating does not adhere well to dirty surfaces and it ABSOLUTELY DOES NOT mix with water. The presence of water will leave you with white spots or streaks that will be even more difficult to remove.
Ford Bronco Fender Flare Cleaning and Protection (How-To) -- Dawn Dish Soap, Sponge, Adam's Polishes Ceramic Graphene Coating IMG_2625
Ford Bronco Fender Flare Cleaning and Protection (How-To) -- Dawn Dish Soap, Sponge, Adam's Polishes Ceramic Graphene Coating IMG_2611
Ford Bronco Fender Flare Cleaning and Protection (How-To) -- Dawn Dish Soap, Sponge, Adam's Polishes Ceramic Graphene Coating IMG_2614
Ford Bronco Fender Flare Cleaning and Protection (How-To) -- Dawn Dish Soap, Sponge, Adam's Polishes Ceramic Graphene Coating IMG_2615
OleGreenBronco
Graydon
Yes I did, it was a piece of cake! There is 5 locking pins on each flare that you turn until you feel a small detent letting you know they’re square with the holes, then you just pull strait out. Putting them back on is the same only in reverse.
This is great to hear! I’m in Michigan and our winters consist of salt covered roads too so I’m hoping they hold up pretty well. It’s funny, I’ve been doing paint corrections and ceramic coatings on the side for years and I’ve never done any of my own stuff 😂 The fenders should make a good durability test.
Wark
Kurt
Syracuse, NY
'22 Ford Bronco
Ceramic coating looks like a good option. I took delivery of my bronco during pollen season and Day 2 I had to do something about the pollen streaking and mud stains after Day 1.
I have been through a fair number of rubber / vinyl cleaners and protectors... I haven't used any of Adam's products. So far, I can only recommend Turtle Wax 50655 Inside & Out Protectant, 23 Fluid Ounces of the ones I've tried.
It goes on easy with a micro-fiber towel for the fenders, mirrors, interior... and I've used it on the MIC. Just apply without washing and it keeps the pollen stains away. Reapply as needed (like every 3 weeks, or less if you're parked under a flowering tree). Bugs wipe off with a towel. There is a lot of rubber/vinyl on the base, including the grille, so this has helped me a bit. I've been using this product since April '22 on MIC and seems fine.
https://www.amazon.com/dp/B01N6IW25N?ref_=cm_sw_r_cp_ud_dp_V44R7JD47APW2GHQBD5W
Ford Bronco Fender Flare Cleaning and Protection (How-To) -- Dawn Dish Soap, Sponge, Adam's Polishes Ceramic Graphene Coating side
Squatch2022?
Kim
1475C0lt0n
F150 and Mustang
I had my Eruption Green Ceramic Coated and it really made it even more amazing! Really brought the color and shine alive! Hard to show in pics! The reflection and shine is mirror like and the surface feels like butter!
Bwaggs83
Brandon
United States
VW atlas
Ford Bronco Fender Flare Cleaning and Protection (How-To) -- Dawn Dish Soap, Sponge, Adam's Polishes Ceramic Graphene Coating 20220525_160310
I use scrubbing bubbles and it gives it a great shine afterwards as well. How long does it last on yours?
OleGreenBronco
Graydon
It should last a couple years hopefully. Ceramic coatings can last a long time as long as they're maintained but I don’t expect it to last as long on the fenders considering how much abuse they take especially over the Michigan winters.
