Factory wireless charging pad - can it be disabled?
sportcoupe
Georgia
2023 Bronco
I have the factory wireless charging pad. Manual advises not to place anything metal in that area, rendering it useless for storage. Can I disable the wireless charging pad so that area can safey be used to store things?
da_jokker
Jeep Wrangler JKUR
If you're talking about semi-permanently disabling it, then just pop the center console top off and unplug it. Will take 5 to 10 minutes.
sportcoupe
sportcoupe
Georgia
2023 Bronco
I would prefer an off/on switch. I didn't see such an option in the infotainment screen.
Disassempling center console to turn it off and back on again is not ideal.
Richterman
Badlands, Superduty
I keep a tin can of altoids there and it hasn't caused any issues.
BigHoof
PA
Ram 2500
Yeah, definitely should have a switch. Our Tacoma has one.
Fuse #3 under the dash is the one used but it also controls the mirrors.
Ford Bronco Factory wireless charging pad - can it be disabled? Fus
KABQ
Aaron
Albuquerque, NM
Just splice in a switch- then you only have to take it apart once. As far as I know there's no other way to turn it off.
da_jokker
Jeep Wrangler JKUR
Yeah you could totally do that. I've drilled a couple holes in my center console on either side of the 12 volt plug. You could totally get yourself one of those round little toggle switches and wire it in to the charger.
Of course just make sure that the switch can handle the amperage (maybe tied in through the negative side?)
