Factory Fog Light Switch
@BadBlueBronco
Kc
Los angeles
2021 Bronco Badlands
Just an update from a Black Diamond - that wire/harness is NOT in the front bumper. So, likely everyone with a 2022 will be better off…as of now it looks like the wiring is at the switch and potentially goes to C203. From there - we’ll have to see. Thanks to @flip for helping me sort this out. Bummed it’s not going to be as easy as I hoped to upgrade the headlight switch and save an AUX.
Dk you know which wire from the headlight the DRLs use?
Bee Bop
Shane
Temple GA
21 Bronco Badlands, 02 Mustang GT Vert, 91 S10
@redone17 Loo and see if you have the connector I circled in red. It should be located in the drivers fender below the headlight. If you have that the all you need is one of the variants of harness 15K867.
Ford Bronco Factory Fog Light Switch 1640562267019
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Unfortunately, that’s not there. It would be visible from under - just behind where the fog lights sit. Unless it’s tucked back because it’s not in use - it’s not there.
I’m planning on taking the wheel and shield off in the next week or so to install catch can and block heater. I’ll have a better view then.
Bee Bop
Shane
Temple GA
Looks like that connector only exists on the 2.7L Harnesses. You would more than likely have to purchase the entire front harness that runs from the BJB and rewire the front of your Bronco, if it is a 2.3L. I had to do that when I added Factory foglights to a 2006 Mustang V6 I owned.
cgguy68
Mobile, AL
2002 Ford F250
That
Let me expand on what I just wrote by listing below all of the pertinent details from various portions of this thread that have been shared to date:
@redone17 shared the following FORScan options
https://www.bronco6g.com/forum/threads/factory-fog-light-switch.22937/post-870566
He also noted that he “Just discovered that the IPC Module also has a Front Fog Lamps that presumably has to be Enabled separately from the BdyCM Module sections I posted yesterday.”
Here is a link to the pic of the pre-wired fog light connectors near front bumper
https://www.bronco6g.com/forum/threads/factory-fog-light-switch.22937/post-898367
@ModifyMike provided a screen-shot of the 4 various switches you can use to replace your factory switch. It will depend upon model/options, and whether you want the front or front plus rear light switching (though there is no pre-installed wiring for a rear fog that we know of yet)
https://www.bronco6g.com/forum/threads/factory-fog-light-switch.22937/post-819923
Here is a pic of one (the -CA version) by @redone17
This is what I could find - can anyone verify that the FORScan setting @redone17 has provided are the complete list, and what those should be set "to" in order to make this work? Thanks!
Is the BA version
hollapm
Paul
SoCal
2021 Bronco First Edition, 2021 Ranger, 2024 F250
Does anyone know what the part numbers are for the dual fog light switch? I know that M2DZ-11654-CA is the Bronco Dual fog, but I don't mind swapping switches from current factory switch to the new switch, and the Bronco is on a national shortage.
geoking
george
Huntsville,AL
2020 GT500 , 2020 F150, 1934, 1948, 1958 , 1966
I have only been able to find the single front fog that enables the swap as originally posted by bee bop. That part number is ML3Z-11654-DA .
I ordered it and received and it works awesome for front fogs ONLY.
So….thinking I was smart, I also ordered
ML3Z-11654-CA . Crash and burn 🔥.
Not even close.
The first 4 alpha numerical set is the vehicle - 11654 is head light switch / interrupter and the -XX is the configuration. I have not found any ML3Z -11654-?? To allow us too go to a dual fog. . If you go to Tasca auto parts on line and searchM2DZ -11654-CAyou will find the only pictorial ( that I have found) of what you and 14 others are trying to purchase. 2 each of the January Backlog orders I know are mine. The Ford inventory system has put the demand in place for these. I recommend you ask @Phil to place one on order and just be patient for the supply chain to catch up. When it does, we can all customize with our personal preferences for updates to rear lighting.
regards,
George King
256 520 4401 cell
Call me anytime
geoking
george
Huntsville,AL
That
Is the BA version
Has anyone purchased a ML3Z -11654-BA and can verify it has the two switches we can swap for our puddle lamps? thank you , George
EDIT 1: corrected part. number
EDIT 2 : I just looked up ML3Z-11654-BA and shows for a 2021 F150 and it''s a no go!
Ford Bronco Factory Fog Light Switch 1641264166227
EDIT #3: the "AA" does not work either
geoking
george
Huntsville,AL
Not even close.
regards,
George King
256 520 4401 cell
Call me anytime
ORDER #1693597 - Placed 11/20/2021
Here's my source ...a copy from my invoice : smile. -DA single fog works
-CA does not have the gas and bed lamp switch to pull for puddle lamp switch swap
Part Number​
Part Name​
Price​
Quantity​
Total​
ML3Z-11654-DA​
Switch Assembly - Headlamps​
$76.05​
1​
$76.05​
ML3Z-11654-CA​
$75.82​
hollapm
Paul
SoCal
Not even close.
regards,
George King
256 520 4401 cell
Call me anytime
Thank you George - I placed an order for -CA about 3 weeks ago. Was told they would get inventory 12/31 but they were only expecting 6, and they didn't know how big the back-log is...
Seeing how @Bee Bop placed one for an F150 but single fog I was hoping there would be a dual fog F150... Appreciate the follow-up. BTW we spoke earlier - I was able to add Fog via Forscan. Let me know if you need any help here.
geoking
george
Huntsville,AL
One last post tonight
M2DZ11654-ba does get you dual but without puddle lamps
Well, that's fucking interesting 👍
I sure like that pretty dual fog switch....grin
TX-Hans
So, which supplier has stock and is shipping ML3Z-11654-DA?
TheeBullhead
M
Minnesota
Chrysler Crossfire
I ordered that switch from Sam Galloway Ford at the end of November and haven’t received it yet.
If anyone can help me get one, I’d really appreciate it!
