Factory Fog light amps draw?
LittleMule#1
Andrew
Cleveland
2023 WILDTRAK, 2019 Expedition MAX
Does anyone know what the factory headlight switch WITH the fog light button is rated to AMPS wise?
Would it be safe to hook up aftermarket LEDS to the factory switch if they draw close to- or right at 10 amps?
T.I.A.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
T.I.A.
You can safely wire in some Diode Dynamics SS3 Max (that's what we run) without issues.
LittleMule#1
LittleMule#1
Andrew
Cleveland
How many amps do the Diode Dynamics draw?
da_jokker
Jeep Wrangler JKUR
So I suspect, And this is truly a guess on my part, is it the factory wiring can provide more amps than the actual factory fog lights use.
I say this because when I pulled off my fog lights, I specifically tested (only one) and it pulled like 0.37 amps or something. I know it was well under 1 amp.
So I was worried, and an ordered some like 14 watt fogs to try to keep the amps down. Then some members talked about how they had installed some pretty decent fogs and haven't had an issue.
So I cancel that order, and change it to some inexpensive, 50 watt Amazon lights. When I tested those, they were lucky if they pulled 1 amp each.
So, I wish I could say for certain, how bright you can buy but I can't. What I can say is that I think with a lot of these being LEDs, they pull less power per watt then the amps/watt calculators. Meaning, it would seem that a 50 watt led fog, only needs like a dozen real watts to accomplish the same brightness.
Steve_In_29
St Johns, Arizona
2024 Heritage Limited, 2 Door, 1973 Bronco, 1999 Ranger, 2007 F350
Old thread I know but I recently asked basically the same question
I ended up attacking my question from a different direction to get an rough answer
It seems the stock (non LED) fog lights take H10 halogen bulbs. Which are rated at 42 watts a piece.
So the circuit should be capable of handling at least an 84 watt (or a roughly 7 amp) draw.
MGF
CA
Bronco Raptor, Merc AMG C63S, Range Rover Sport PHEV, BMW 328i
OEM fog is 10A
CalvinT
Calvin
Phoenix, AZ
OEM fog is 10A
I think that's high. I think the stock fog lights are 20 W for the pair. I replaced my with DD Elites which are 20 W each and they're much brighter.
CalvinT
Calvin
Phoenix, AZ
Steve_In_29
St Johns, Arizona
Which "stock" fogs? The halogens or leds?
MGF
CA
The circuit is 10A fused
Oldhippie
Barry
Santa Cruz, Calif.
OEM fog is 10A
I would like to know where this spec comes from. I do not believe the stock circuit is rated that high from what I was told by dealer tech but have never seen a real spec…
According to DD, my DD SAE pro fogs draw 2.7 amps each and they work fine on the stock fog light circuit.
MGF
CA
When I was setting up my modular bumper lighting, John @ SPV knew the ratings
MGF
CA
When I was setting up my modular bumper lighting, John @ SPV knew the rating of the OEM fog circuit.
CalvinT
Calvin
Phoenix, AZ
