Everglades Owners: Replaced your windshield yet???
Figmo
Figmo
Frenchtown, MT USA
Suzuki Samurai, Bronco 2Dr WT, Gladiator Rubicon
Added an Everglades snorkel to my WildTrak. Took it into Safelite to have the windshield replaced and they refused to touch it because the snorkel overlaps the glass a little. Told me somebody will have to remove the snorkel first since they don’t do that sort of work.
So this weekend I took the snorkel off but even the A pillar bracket extends over the glass a little. I’m going to send a pic to them on Monday to see if they think that is still a no-go. Man I hope it’s not a problem because that bracket is glued on. Hate to have to scrape it off and reattach it.
So can somebody who drives an Everglades tell me if you’ve ever had to replace your glass yet? I’m wondering if maybe when I installed my snorkel I got the alignment “just a little wrong”. Everything does line up perfectly but maybe the guys on the Ford assembly line know that you have to push it away from the glass a little to allow for future windshield replacement and I didn’t do that.
Ford Bronco Everglades Owners:  Replaced your windshield yet??? IMG_0658
BD6G
Everglades
IN
24 Bronco
Everglades
There is a slight overlap as well from the factory, I’ll get a picture of mine and post it here as well.
Edited to add I have not had to replace my windshield yet.
BD6G
Everglades
IN
24 Bronco
Everglades
As you can see your install is correct there’s a slight overlap
Ford Bronco Everglades Owners:  Replaced your windshield yet??? IMG_4928
Figmo
Figmo
Figmo
Frenchtown, MT USA
Well that’s good news bad news.
Glad to know I didn’t screw it up.
But if removing the snorkel truly is required for glass replacement - then that is clearly bad news to ALL Everglades owners out there. Especially if glass shops are unwilling to remove it.
Means a 3 step process to replace your windshield:
  1. take to mechanic to remove snorkel
  2. take to glass shop to replace glass
  3. return to mechanic to reinstall snorkel
Ouch. Future Everglades buyers might want to consider this.
BD6G
Everglades
IN
24 Bronco
Everglades
I added the bug/wind deflector. This helped tremendously on my previous Bronco and hoping it helps again or at least continues to mitigate the risk.
Ford Bronco Everglades Owners:  Replaced your windshield yet??? IMG_4924
R.A.N.M.J.
Rick
It was one step for me. I took it to the dealership and they replaced the windshield on my wife's Everglade in one visit, in about 4 hours.
Figmo
Figmo
Figmo
Frenchtown, MT USA
Can a Ford tech or somebody with a service manual for the Everglades give us an "expert" ruling on this?
Does the service manual call for removing the snorkel in order to replace an Everglades windshield?
If so, does it call for removing the A-pillar mounting bracket as well? If so, what about the double sided tape that glues this bracket in place? Is that available as a separate part number? (obviously, you can't reuse it)
turtlespit
Everglades
Central Florida
2024 Bronco
Everglades
Snorkel comes off super easy! Have already replaced the windshield. I also had a Defender with a snorkel that was the actual nightmare you're envisioning.
Figmo
Figmo
Figmo
Frenchtown, MT USA
Yes I know. I installed it. ;)
So I’m guessing you did NOT have to remove the A-pillar bracket to replace the windshield? Because it also protrudes over the edge of the glass. Just not the whole height of the glass top-to-bottom like the snorkel itself does.
Ducati1098
There are no specific instructions per model.
The only thing the workshop manual says is:
NOTE: Some interior trim, exterior trim and/or components may require removal based on the tools and removal method used.”
