Engine surge at low speeds
Keith J.
2024 Bronco
I just bought a new 2024 Big Bend 2.3 Bronco and I've been experiencing a low speed/low RPM engine surge when coming to a stop. Happens cold or warm, sometimes worse than others. I noticed it after installing a Corsa cat back dual rear exit exhaust system. Prior to that I installed a Corsa catch can and cold air intake. I didn't notice it until after the exhaust was installed. Maybe it was there the whole time but I just couldn't hear it because the exhaust was so quiet? The vehicle doesn't lurch or anything like that, but the RPM will fluctuate only when braking such as coming to a stop. Just wondering if any of the aftermarket parts have caused this for any of you? No codes or check engine light, just annoying. Thanks for any input.
JKal
Jacob
2023 Bronco
I noticed this during cold start in the break in period, but went away around 2k miles. Now on 5k miles still haven't felt it again.
Keith J.
Keith J.
2024 Bronco
Ok thanks! I’m hoping it’s just a break in/learning thing because it’s extremely annoying.
KABQ
Aaron
Albuquerque, NM
Is it the AT? It is probably just the transmission downshifting.
dgorsett
colorado
F250, Mustang, Explorer
Put it in Sport mode, it will be exaggerated.
dgorsett
colorado
Really? If so, that sucks.
Well, just because in Sport the transmission has a more aggressive shift strategy both up and down.
TXBronco1313
7k on my Bronco and I’m starting to notice the same engine surge everyone is talking about. Did anyone figure out what is causing it or if there’s a fix? I have the 2.3 auto engine
Alanp970
Alan
2023 4 Door Base Sasquatch Hardtop
I’ve got 21K miles and mine does it occasionally. I don’t think it’s just the transmission downshifting because mine will actually lurch forward slightly like I tapped the gas pedal. No engine or exhaust mods on mine. I may go months without it happening so I haven’t been concerned
TXBronco1313
Yep same here I don’t think it’s the transmission it might be the fuel pump but I’m not 100% sure. I’m glad at least I’m not the only one it’s happening to
Keith J.
Keith J.
2024 Bronco
As soon as I installed the Ford Performance tune on it everything cleared up, hasn't done it since. I'm thinking that it had something to do with the aftermarket cold air intake or the aftermarket exhaust.
Keith J.
Keith J.
2024 Bronco
Ford Performance tune took care of the issue on mine. Hasn't done it even once since installed.
Area51BS
Ron
Badlands non SAS 4dr 2.3
Are you sure it’s not the adaptive tranny? Get it reset
TXBronco1313
Haven’t done a Ford performance tune and with all honesty I’m not sure what I need/what to do. Any help guiding me through that would be appreciated
