Engine surge/acceleration when downshifting
Regulator Johnson
2008 FJ Cruiser
I just got a BL SAS, 2.7 auto. Did my first trail ride and experienced the following. When going down steep hill and manually downshifting to first or second gear, the engine would surge and the vehicle would accelerate (foot definitely off the gas pedal). Not a nice feeling when it is steep and rocky. I was in 4L rock crawl mode. Anybody else experience this or have an explanation?
TABadlands
Todd
Clayton, CA
2012 Mustang GT; 2022 Two Door Badlands
Yep, unfortunately it's a thing. It was discussed at the Nevada Off-Roadeo when I attended in November. Not sure if there's a fix yet? But I know what you mean. It's a little sketchy shifting going downhill
mike8675309
Minnesota
Did you mean downshifting going downhill? That's what the was stated here, it was when downshifting.
Sounds like a programming issue related to some preprogrammed shift behavior with the throttle closed.
Drex
Jake
engine breaking force was overcome by gravitational force because you were going downhill. Without using the brakes, your engine revs higher due to the mechanical linkage to the tires/ground as your speed increased until your engine braking matched your downward velocity component. It is very likely that the computer opened the throttle for emissions as a rapidly closed throttle leads to increased NOx emissions. This would greatly lessen the amount of engine braking available.
TABadlands
Todd
Clayton, CA
It happened to me upshifting from manual 4WD Low toward the bottom of a hill. I didn't experience it downshifting. But I didn't downshift part way down a steep hill. I was already in manual 4WD Low at the top of a steep decline.
Regulator Johnson
Regulator Johnson
2008 FJ Cruiser
Was there any mention of what might be causing it, e.g., computer software issue?
TABadlands
Todd
Clayton, CA
It's definitely computer related. I don't recall the specific details the Off-Roadeo Instructor told us regarding why this happens.
Tom
St. George, UT
2022 Bronco Wildtrak, 2017 Toyota Tacoma Off Road
I have had the same problem and wondering if there is a fix. Going down a 25 percent slick rock incline and it has happened to me several times. rather scary.
shnider10
Dustin
WV
2000 Chevy Impala
Did you ever get an answer on this? Mine is doing the same when manually downshifting the 2.7 auto it will act like it’s going to accelerate and then begin to gear down.
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
Experienced the same here too. Bad enough where my 7 year old son noticed it and said “dad why did you speed up?” I didn’t have an answer for him, just like the rest of us here.
