Engine Rattles Under Load
Malnik77
Irvine
Rav4
I have a 2023 Base Sasquatch with 2.3L automatic with 55k miles
Recently I noticed intermittent engine rattle during acceleration and under load, like going up a small incline. It occurs about 10 minutes into the drive. Not when the engine is cold but when the engine oil is at around 187-189 degrees Fahrenheit.
The rattle sounds like there is a hole in the down pipe, almost like a Dodge Hellcat. The gas pedal will also have a slight vibration. The noise and the vibration disappear after a few minutes. It happens at almost every drive.
The dealership mechanic had the car for a few days and said it drives normal. He did not say if they replicated the problem or not. Research from online and this forum suggest it could be loose turbo wastegate, spark knocks or normal 2.3L behavior. Strangely, most of the people experiencing rattle are at cold start. Mine comes on after 10 minutes of start.
Anyone else have this issue or know of a fix?
One thing to add is that I had a leak in the timing cover a few months ago and the dealership replaced the seal. Anything they did there could have caused issues?
Malnik77
Malnik77
Irvine
Rav4
I filled up the gas tank a few times since i first notice the rattle. If there was bad gas it would have been used by now. No change in gas. I've been using 87 octane since the beginning.
CalvinT
Calvin
Phoenix, AZ
One tank full of premium would give you a quick double check. My first guess was pre-ignition.
Here's a question, does the 2.3L have a preignition sensor? I suspect it does since power output changes depending on fuel. Could it be bad? But if it was, you'd think you'd get a code.
Desmolicious
SoCal
2025 Bronco HE, MX5
Run a bottle of injector cleaner through it - Chevron Techron or whatever - and try a few tanks of premium gas. From a top tier gas station.
Pre-ignition/knocking is the easiest thing to check first before digging into more costly causes and solutions.
Fordified1
Bob
Mid South Texas
Use 91 or 93 and it will run better and get better fuel mileage and NOT rattle (if lack of octane is indeed the issue). Running 87 in a turbo charged vehicle leaves so much on the table. But alas it may already be carboned up from the cheap fuel.
CalvinT
Calvin
Phoenix, AZ
This makes it odd and rules out fuel being the problem. Exhaust gas leaks can sometimes make the sound you describe.
Red2000
2022 Bronco
"almost like a Dodge Hellcat" A lot of people are looking for that v8 sound in their bronco nowadays :)
I don't have much constructive to say. Maybe try recreating the issue with another person driving or in the passenger seat.
Desmolicious
SoCal
2025 Bronco HE, MX5
it is odd, but I would first check for the easiest/most basic thing then work down the list.
This isn’t a bad idea - but you have to use the aerosol injector cleaner through the air intake - stuff in the tank does no good on Direcr Injection.
Also the basics - check for codes, clean air filter, check oil&coolant levels, etc
calbare
Jose
Napa, CA
2025 Ford Bronco Heritage
Not sure, but going over rough roads, I would get an intermittent rattling noise. It turned out the exhaust had a loose/falling off clamp. Only happened when driving on bumpy roads. Might be good to check that.
ComptonRides
Taylor
Fayetteville, Arkansas
2022 Bronco Badlands Sasquatch
A couple weeks ago I had a catalytic convertor replaced under warranty that had failed. Small pieces of the cat had broken off and fallen down into the flexible section of the exhaust and was causing a rattle similar to what you are describing. Could be worth a check.
Malnik77
Malnik77
Irvine
Rav4
Im still trying to find the source of the rattle. I checked the turbo wastegate actuator rod and it rattles a bit. Can anyone with a 2.3L engine checked if yours make the same rattle? Its on the passenger side. Thanks in advance
Wastegate actuator rod rattle
