Engine fluttering sound upon acceleration | 2.3L
SamG
Sam
Detroit Area
sas
Golly I hope I am over-reacting and being paranoid, but in my experience with vehicles, I rarely am...
Bronco hit 1800 miles recently and suddenly its making an odd fluttering sound when accelerating - seems to be correlated to the RPM's.
It borderline sounds like a leaf is stuck in a fan blade - however I checked and I see no leaves or other debris anywhere in the engine bay.
Video of the sound below - it becomes very prominent at about 12 seconds into the video. make sure your speakers are cranked as its hard to record from inside the cabin.
Does anyone's Bronco sound like this while under acceleration? Any idea what this could be?
Another note; I've noticed when I initially start the truck she idles at 1.2k RPM - is that standard?
Lifeliberty
Moonbeam👀
Columbus, OH
I dont hear anything that scares me. Never had turbo though.
Could just be valve noise, my accord is noisy, runs great
Spooled
Republic of Texas
Raptor, Model 3
I can't hear anything weird with headphones on and the volume cranked. If you've experienced any power loss I would chase down a possible boost leak. That's more of a whooshing sound, though.
t0sserlad
Minnesota
2019 WRX
Fluttering from a turbo engine is usually just the sound of the wastegate. That video sounded normal to me. The engine sound of the 2.3 is way louder than the 2.7 in cabin too.
Lifeliberty
Moonbeam👀
Columbus, OH
Last bronco has exhaust leak, could be your flubbing sound.
Hornet
Ford Explorer
Under warranty take swing by the dealership.
Blue's B6G
Jeremy
Los Angeles
2021 Bronco OB 2-Door V6 Sasquatch AMB High Pack
Yes I do remote start while putting on my shoes and let it idle down to 800 RPM before pulling away. After warm it’ll go into what I call Stealth Mode where it idles silently at 500 RPM in drive thrus, longer stoplights and whatnot. I assume this is all normal.
Rick Astley
Up Doug's ass
d
Easy things to check for vacuum leaks: worm clamps on intake, intercooler piping and wastegate/BOV.
Warm-up idle being high: Yes, this is standard for modern small displacement automobiles as there are emissions requirements. That is the ECU tuning doing it's job to heat up the catalytic converter as quickly as possible as they don't function while cold.
https://www.sciencedirect.com/science/article/pii/S2214157X18304301
erics667
Minnesota
2021 Badlands 2.3L MT A51, 1974 Ford Bronco Ranger
Sounds like my 2.3. I do not hear anything odd.
MrJoe
Southern Maryland
'73 Bronco (sold), '99 Ram, '08 Explorer, '16 CMax
It's getting cold out. Could be butterflies hibernating in the air box?
Moparguy
Mansour
2010 MX5 GT - 2010 MX5 T
I would head to the dealer, car under warranty.
I didn't hear anything weird.
BadCactus
Derek
West Linn, OR
2021 2-Door Badland 2.3L 7M | 1991 EB
I can hear a slight rattling noise. Maybe give the turbo heat shield a look (when the car is cool, of course). Have you added any modifications - air intake, exhaust?
rgates135
Ryan
Maine
Have you found the solution to this yet?
Thank you!
John94
Detroit
4dr Black Diamond Sas
Thank you!
No solution yet. issue has got worse.
someone suggested it could be related to the shifter cable
