Ebay 2 inch lift cheap
0ne
Nate
CO
Flex
Get what you pay for? 🤷‍♂️ All the cheap lifts no matter the brand, manufacturer, or country of origin will put your factory engineered geometry out of specification and possibly lead to failures possibly not covered by warranty. Ford has put Easter egg “lift me baby” messages on these Broncos so if you’re chasing a look I guess mother Ford approves.
Debc
Debc
Deb
Pennsylvania
TAcoma
Lol mother ford
FrankenRodz
sheldon
Massachusetts
2022 Base 2 - Door
Not a fan of that style. Looks like Rough Country.
I went with Ready Lift.
Solid Billet Aluminum for a decent price.
Ford Bronco Ebay 2 inch lift cheap 8DD3234C-547C-4CC2-AF29-AB5095F02AA4
Felix808
SRV CA
Don't waste your $$ or your CV's.
rtazz17
Connecticut
2022 Ford bronco big bend
if youre going 2 inch do ready lift solid billet as stated above. Your talking 200 bucks more for a solid product imo. Ive done so many things twice. Ive learned now to do it once,correctly. Although some will argue a spacer lift is incorrect. I can see both sides of that argument
Oldhippie
Barry
Santa Cruz, Calif.
Looks like they are just tack welded?? They would probably be ok if ya finish welding them...
Tricky Dick
Dick
PNW
www.TD-Distributing.com
I've used a very similar looking cheap chinese lift on an older explorer once and it was fine, but the Bronco deserves something a little nicer.
BottleShark
TJ
East Texas
Nautilus, Samurai, 12v Dodge, Fiero, Karma Ghia
1st off, a 2" spacer or puck lift from any company is going to effect CV angle the same. So anyone telling you otherwise doesn't have a clue what they are talking about.
The difference in U.S. vs China is up in the air. A Chinese company can use high grade steel and make a quality product. Or a U.S. company can use low grade steel and make junk. I've had mixed outcomes for the past 20 years of building cars and motorcycles.
If you go the eBay route, I would bet they would be just fine. Just inspect the welds. Remove a little paint from the back side of the weld with chemical stripper and make sure there is good heat penetration. Or go with a solid aluminum spacer, as they don't have welds to worry about.
Remember, these parts are in compression and don't experience side load. So the import part is good hardware, so it doesn't pull apart if suspension completely extends. Metric grade 8.8 is equal to a "Grade 5" use bolt. So make sure to use Metric Grade 10.9 bolts.
BottleShark
TJ
East Texas
