Easy bolt replacement for hardtops
tjnoffy
Jay
Maryland
'21 Bronco OBX Sas, '22 Escape Hybrid, 2 Harleys
Similar but the ones I show are fixed without movement and the ones you show can move.
I guess the ones in OP's post are "hinged" in a way. Maybe prone to flopping around and rattling? Anyway, I was just trying to confirm whether similar tie downs were actually available with these handles.
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
Um, who at Team Bronco never thought these should be standard?
There is going to be a large majority of people who never remove their top, and for whom the stock bolts will be less obtrusive for their suburban (or cage racked overlanding) tastes.
These things have great utility. But even for my case where the top comes off / goes on seasonally—swapped out for a soft top—they’re not as useful.
Bronco4lyfe85
William
2019 Challenger Scat Pack
Was thinking the same, how often are you taking off the shell? That’s a PITA. Do it once and leave it off for a few months.
Lifeliberty
Moonbeam👀
Columbus, OH
My lame assed review:
I ordered, got in 5 days to Ohio. Look nice.
Do they hold up? Last, fit etc e.t.c, i don't know. Just nice to have options. Glad i got on sale, dunno how id feel about paying full price. D plates are sturdy, nice finish. Packaged well
Thinking these bolts will rust, I'll probably use antiseize with them
Ford Bronco Easy bolt replacement for hardtops 20211120_112627
Ford Bronco Easy bolt replacement for hardtops 20211120_112851
Silver-Bolt
Bill
Eureka, MT
How much are they for the set?
j_marinelli
Spring Branch, TX.
Quick feedback on the flat anchor set.
I got them and they are bigger than expected but unfortunately won't work for the intended use on the Bronco.
Here is pictures of them in place in the 3 different spots:
completely blocked:
Ford Bronco Easy bolt replacement for hardtops 20211128_160640_resized
partially blocked:
Ford Bronco Easy bolt replacement for hardtops 20211128_161104_resized
second bolt blocks from being flat and still is partially blocked:
Ford Bronco Easy bolt replacement for hardtops 20211128_161327_resized
I did find a home for 2 of these up by the rear speakers though. I will probably keep these on there until the Sinister hooks are back instock and order some of those. I will probably look around a little more on the Bronco to see if I can find a new home for these.
Ford Bronco Easy bolt replacement for hardtops 20211128_161830_resized
Ford Bronco Easy bolt replacement for hardtops 20211128_162240_resized
Doc Rocket
US
Ford Bronco, Base, Sasquatch
Got the T-bolts (and the D tie down plates) installed. I mainly wanted the T bolts as a tie down location for a couple of things, just to hold some gear bags that I usually keep in the vehicle (some tools, jumper cables, etc)
Ford Bronco Easy bolt replacement for hardtops 20211204_104332
While I agree with one of the previous posters that the D plates are a bit blocked, one of my eventual plans is to make a cargo net/tonneau in there to cover the cargo area, and I think that the D plates will be helpful at that point to attach webbing.
Closeer view:
Ford Bronco Easy bolt replacement for hardtops 20211204_104337
The passenger side:
Ford Bronco Easy bolt replacement for hardtops 20211204_104346
Both bags are from Duluth Trading Company, but I am not sure that either is still available.
BigDaddySquatch
Tony
Madison, AL
2012 Toyota Tacoma TRD Sport
Does it not rain where you live?
Bronco4lyfe85
William
