E rated tires and TPMS- question
SeaVee
Greg
Va Beach
2002 2500 Suburban, 77 Bronco, 2001 Cherokee
So if I go to E rated tires what’s that do to the factory TPMS system? Swapping them onto a stock OBX.
Just wondering what that does since you don’t get E rated tires from factory.
TIA
SeaVee
Greg
Va Beach
Thanks!
AZ_Liberty
2007 Expedition
Nothing changes. The TPMS only alert if you go low pressure, not high.
I'll be going E-rated as well (like I do in all trucks/suvs) and am not concerned about it. Cooper makes one C-rated 265/75R16 that looks tempting, otherwise there are so few C rate choices that E-rated is really your only option if you don't want a soft mini-van tire.
mountainbronco
I switched from factory 32 inch C rated on steelies, to Method 302 with BFG K02s E rated (now 33 inch). At the time of the switch, I purchased 5 new TPMS sensors and installed in the new Method wheels.
All worked without a glitch, the Bronco quickly learned the new codes without any inputs or reading of the codes.
Then, at 8000 miles I rotated tires with the 5th spare included, and voila, same thing happened - absolutely no issue. The Bronco can differentiate the spare and not include it in the readings.
The TPMS display simply shows the current pressures, regardless of C or E rating. I don't even know what the low pressure warning level is, but when I get that offroading, will just have to press "OK" a few times, but I would have had to do that with the regular C rated 32 inchers also.........................
