Dump $8k into a Base or Trade for BaseSquatch?
Tidewater
Southern Maryland
2014 Raptor SCREW & 1981 CJ8
Go SAS. Lots of value in the front end/gears and suspension
ramblinwreck
Georgia
`22 Wildtrak, '21 Wrangler Rubicon 4xe
You can have a better suspension and wheels / tires for significantly less than $8k on the base. Yeah you’re missing out on the lockers but it’s still an extremely capable machine.
You are missing out on suspension, lockers, larger axles, advanced transfer case, warranty, gearing and resale value. It’s honestly a dumb move to not buy the Sasquatch, even if you do end up swapping wheels.
VoltageDrop
Fidalgo Island, WA
23, 69 Bronco
Have you not seen the base sasquatch fender badge? I'll say no more.
NVCowboy
William
Henderson, NV
2002 F350. 2022 Big Bend (Sasquatch)
My Sasquatch hasn’t even seen gravel yet. I love it. I’ve seen seen some videos of hardcore wheeling that the locals are doing around here. Hard no. My intended use is hunting along with recreational wheeling on forest service and BLM roads. I’m still very happy to have Sasquatch. I’d trade.
Roger123
Roger
VA Beach, VA
"if I am honest, it may be overkill for 98% of what I need. I currently have no experience with more technical rock crawling"
You answered your own question, keep the base and use the 8K either to pay it off or if it's paid for put it in your retirement account. Or take 1K and upgrade your tires to maybe a set of BL takeoff's. If you'd be financing the 8K then absolutely do not do the deal.
You don't even know if you like off-roading, give it a year and see if you like it or have the time to do it often and then make an informed desicison.
You sound like you have "upgrade fever", take it slow for a bit and see how it plays out. You can get out and have a TON of fun with your current vehicle.
Calm horse
MO
Georgia
17 f150 king ranch
Squatch! FACTORY WARRANTY! Resale value...axles..gears...cool buttons that you may or may not use..and the badge alone is worth 8k
JojoReady
North Country
Silverado
The basesquatch you’re looking at better already be built or scheduled with VIN. Basesquatch production for MY23 is ā€˜balanced outā€˜ and no more will be scheduled this model year. It’s also very possible that Ford will drop squatch as an option on base and other lower trims in MY24.
Haelous
US
2016 Mustang GT, 2023 Bronco Wildtrak
You're missing too much from non-SAS to SAS if you want it or are going to use it. Trade. Retrofitting the transfer case will be a huge undertaking and likely have a negative effect on your powertrain warranty.
Quitefrankly
WA
100 percent SAS and you will be thanking yourself.
not to mention as an A51 owner myself Cactus Grey will have higher resell.
BroncoAZ
Mitch
Is this actually a question? Base is awesome, but Base SAS is better in every way except the $8K and MPG.
Broncoblk23
Massachusetts
2022 Jeep Gladiator Rubicon
Go with the Sas. After you spend the 8k if you every decide you want/need axles and gearing you’re adding more K’s
NVCowboy
William
Henderson, NV
I’d never considered your last statement, but it makes logical sense in this climate (I’m not in favor, but it makes sense). If they added locker as an available option to Base, that’d keep the howling down (one, maybe two decibels). It’d sure change the Bronco universe as we’ve come to know it. Might result in the following trim levels like some members have suggested:
Bronco (just Bronco, combines Base and Big Bend) No SQ
Badlands (Optional swaybar disco, combine BL & BD) SQ Available.
Outerbanks - Squatch Available
Wildtrak (Hoss 3.0 Glory)
Special Trims
JojoReady
North Country
Silverado
Special Trims
I think you’re spot on with what Ford is looking at, fewer trims and more available option packages. Fordā€˜s current offerings were put together when constraints weren’t as big an issue and they rigged the B&P to force you to higher more expensive, profitable trims to get an option you wanted even though you didn’t need a lot of the other extras. For example, how many people upgraded to Badlands from BD just to get a manual tranny with mid even though they didn’t need front lockers or stabar disco?
With reservations and price protection out of the way, Ford can rethink how they distribute options, trims and packages to get a higher number of buildable orders at higher prices and more profit .
