Dual Compressor Install Location "Options" ?
Gtrekker
Gary
Hey,
It seems the primary mounting location is on the passenger side engine bay. For me, I'm thinking on going another route...
What "OTHER" locations seemed to work for you? How did you deal with the heat issue and / or protect it from the elements (Dirt, salts, Mud, rocks)?
* Under the vehicle?
* Cargo area?
* Installed under a seat or panel?
Photos would be GREAT!!!
Thanks....
Beach_Bum
St. Augustine, FL
2023 Outerbanks Bronco
If you don't have the LUX, you could look at the space the sub-woofer would occupy in the rear cargo.
The sub-floor cubby in the cargo seems to be too small for a dual compressor.
@UtahBrandon might have a solution for you if you have a 4-dr. He had a bracket designed to be mounted to the rear rollbar. If that original bracket can't be sourced, then perhaps his Attic Storage Shelf might serve as a mount for the dual compressor.
I'm of the mind to keep the compressor out of the elements. I'm not a fan of the rear spare tire mount. Locating it under the chassis is also a non-starter. While the engine bay is still dusty, it provides protection from mud and salt while also shielding the passengers from noise and heat.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Hey,
* Cargo area?
Thanks....
So our KR Off-Road engine mount is the most popular. It's just easy and keeps it out of the way. It's also super easy to wire since your battery and upfitter wires are right there.
Another place i've seen people install them is the cargo spot in the rear. However only a single compressor seems to fit in here. The dual compressor doesn't quite fit. You'd have to run a harness up to the battery (10 guage for a single or dual 10 gauges for a twin) plus your upfitter control wire (might as well since you're running wires anyway).
You can also install it under your seat as well. The wire run won't be as far when you do this but it'll be inside your truck now.
Gtrekker
Gtrekker
Gary
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
deuberj
Robert
Hudson, Ohio
2022 Bronco
I am looking for a place in the engine or maybe in rear cargo area (where sub woofer would be) for a Dual Compressor installed
I have a Everglade so the snorkel is where the normal engine mount would be
I have seen this for a single and seen where a single would fit in cargo cubby in back. But would like to do a dual if possible
Ford Bronco Dual Compressor Install Location "Options" ? IMG_3466
Ford Bronco Dual Compressor Install Location "Options" ? IMG_3464
Ford Bronco Dual Compressor Install Location "Options" ? IMG_3467
Ford Bronco Dual Compressor Install Location "Options" ? IMG_3465
Ford Bronco Dual Compressor Install Location "Options" ? IMG_3463 (1)
contented
Karl
Central Fl
BMW M2 Competition
There's only so many places to install one. I used the KR Off-Road brackets from 4x4 LED's. Below is my setup. I wanted the on/off switch next to compressor.
Ford Bronco Dual Compressor Install Location "Options" ? IMG_0919
Ford Bronco Dual Compressor Install Location "Options" ? IMG_0916
deuberj
Robert
Hudson, Ohio
2022 Bronco
Thanks - I ideally would like that install, but I think on mine the exhaust is in the way
contented
Karl
Central Fl
BMW M2 Competition
Yup, each trim and engine seems to be a bit different. I have the 4 cylinder badlands. Would love to be able to move winch controller to engine compartment, but no room. :-(
The only words of wisdom I can offer is to think thru how you’ll use the compressor, location of on/off switch and what you plan to connect to it.
Good luck.
Gtrekker
Gtrekker
Gary
I like it! I'll probably end up doing the same... Thx!
