DRL and headlight turn signals not working.
kyyyylllleeee
Kyle
Western North Carolina
Has anyone had an issue with your DRL’s and turn signals not working? I have a 2023 badlands 2.7. Just picked it up from ford to have my 60k mile service done. They also fixed the camera recall and fixed one of the rear windows that wouldn’t roll down when opening the door. Said they had to mess with the software of the vehicle to fix it. Now my low beams are on instead of my DRL’s and the turn signals act like there’s a blown fuse and none are blown
derichio02
Bo
Southern California
Bronco Badlands, Maverick, Tesla M3, F250 Tremor
I don’t have any of the other symptoms but my rear right turn signal acts like it’s out on the dash but the light itself is actually working.
pillio35
Bay Area
2022 Bronco Badsquatch
I have the same issue with the driver DRL/turn signal not working on my 2022 Badlands too. Please update here if you ever do find a solution.
NC_Oak
2024 4 door 2.3 sasq
well forscan will show you more than a regular code scanner. My guess would be a ford tech will reset / reprogram the module.
But mainly I was asking to see if you've made any changes. I changed my indicators to be on with DRLs, so if I had an issue the first thing I would do be to reload the original as-built back on the module.
Bigmoose
Jon
RI
2019 Flex Ecoboost Limited
Any chance you swapped to raptor headlights?
