Driving Bronco without Beauty ring?
kkurni
WA
Mini Countryman
I don't like the looks of Beauty ring on sasquash package wheel.
Can remove them and drive around without it on road / offroad?
What is the benefit of using beauty ring?
Do I need to put screws on each hole without beauty ring attached?
wilmerfjohnson
Wilmer
Moore Twp, PA
2018 Fusion, 2009 Mariner, 2000 Taurus, 1996 Bronco, 1994 F-150, 1988 F-150, 1984 Bronco II, 1978 F-350, 1974 VW Thing
Hey! Good question - I never thought about it before reading your post, but if it isn't on the vehicle it can't get broken, scratched or hung up on an obstacle. If it isn't needed, take it off!
Raptor.Tremor.Bronco
Miami, FL
2021 Bronco Wildtrak, 2014 Raptor, 2020 Tremor
You can run without it. I don't think it looks good without it and you risk damaging your wheel instead of the ring. I would buy more bolts and fill all the holes.
Compta38
Alabama
Ford Fusion
If you have the silver ones just paint them black to hide them better.
okbob
North of the Red
71' u15, 66' u14, 66' u14
AceGoliath
Charles
IL
21 Bronco OBX SAS , 22 Maverick XLT, 10 Fusion SE
The rim is “unfinished” under the ring. You’ll see some bare metal vs the black coating. You can kind of see the unfinished surface in this video when he takes the ring off.
Snydermann
Tim
South East, PA
Samurai, VW Thing, MINI, smart, Astro Van
That video was painful to watch. He's definitely never worked flat rate. :)
BlazinGTO
Dustin
MA
2004 GTO M6 2004 Escape
Felix808
SRV CA
Had to watch because of this comment. Don't use a torque wrench as a ratchet people. :cool:
Rkgzx9leftcoast
Robert
Scottsdale AZ
Jeep JL
Simple answer is yes you can...But , if you off road without them on and scratch the mating surface of the rim , meaning the surface behind the ring, they will never be able to be bead lock rims without costly repairs. Not that you intend to use them that way, just an FYI
kkurni
WA
Mini Countryman
What is the implication of keeping the unfinish metal open?
Will it be corrosion if I don't put any paint or wrap?
kkurni
WA
Mini Countryman
Ok thanks, will it corroded if I don't protect it with any paints?
Or will it still safe to drive on road?
