Driver's Side Seatbelt Not Retracting
SoCalG
SoCalG
Southern CA
2022 2DR Bronco BD
Weak tensioner is my issue. slow to retract and I have to baby it to get it to retract all the way or I end up slamming the door on it :mad:
First dealership (Star Ford Glendale) said no to repairing it. It's at Galpin at the moment getting the 2.3l Brake vacuum hose TSB taken care of along with the windshield recall.
I've asked that this be looked at.
Waiting to see if they will take care of it. It only has 8k miles on it
SoCalG
SoCalG
Southern CA
2022 2DR Bronco BD
I have had no luck convincing them to replace them under warranty.. its obvious there is an issue as the passenger side works fine and you can see the difference.
jjjaz
Phoenix, AZ
22 Braptor
Hey there! I can look into your Bronco’s seat belt concerns on my end if you’d like. Will you send us a private message with your VIN and dealership info?
Did you discover anything on this issue? I am experiencing the same. It has gotten progressively worse and now not retracting without manual assistance. 22 Bronco Raptor.
BroncocnorB
Paul
Clearwater Beach
1965 Cobra,
My 2 door belts don’t retract in front. They kinda flop around and I have to coax them back in. Very annoying
DJ Starr
Minnesota
2021 Bronco Basesquatch, 2015 Fusion Hybrid
My seatbelt is dangerous at this point. My selling dealer ordered a replacement on warranty a few months ago. Unfortunately, I relocated before the part was delivered. The dealer in my new town says they cannot even 'diagnose' the issue until 10/9 at which point, then they can order the replacement part. The performance of the tensioner has degraded so much now that even if I lean forward to change the volume or temp, it will not retract. I have to manually spool it back in every time I get out. It's a huge trip hazard for anyone trying to get out of the back seat too.
I asked if they could 'diagnose' at an oil change - 'no'.
I asked if they could contact the old dealership for the diagnosis - 'no'.
I asked if they could proactively order the parts because I need this fixed regardless if it's warranty or out of pocket -'no'.
I asked what happens if I die in a wreck between now and Oct 9, when they can diagnose it or heaven knows when they can actually fix it? No reasonable answer was given.
What are my options at this point? I suppose I could take solace in the fact that my kids will own FoMoCO upon my untimely death but I'd much prefer the alternative.
AZMikeL
AZ
Easy fix as it's due to dirt/dust buildup on the belt and hanger. Run a feeler gauge thru the hanger both above and below the belt - use a thicker size one that is snug. Then clean the belt with a damp cloth (no soap needed). Takes < 5 minutes and works like a charm every time.
I need to do my driver seat again as it's starting to get a little lethargic.
BroncocnorB
Paul
Clearwater Beach
1965 Cobra,
Don’t think it’s dust and dirt- mines pretty clean. But they definitely need some Viagra. I’ll tell my dealer when I’m in next time. Should definitely be warranty issue, and even moreso since they are safety related equipment. I had a ‘93 Acura that dealer replaced all seatbelts 10 years later when they failed to function properly (retracting)
Hunter45
JJ
2023 2d Outer Banks
Anyone else experience this? It's gone from a slow retract, to retracting only after I exit the vehicle and shut the door, to now not even retracting after I buckle myself in...
I'm having the same issue
Figmo
Figmo
Frenchtown, MT USA
Suzuki Samurai, Bronco 2Dr WT, Gladiator Rubicon
Add me to the list. Cleaned the belt and slot with alcohol and that helped. But that last 6-10 inches still won’t suck in without me manually feeding it. It’s definitely a weak spring.
Ford could save a lot of warranty claims if they’d just give us a way to wind that spring a couple turns heavier.
Oh well….time for another warranty claim call…
Spraying the belt with dry silicon lube AFTER CLEANING helps a ton.
Granted I’ve never had to do that on any other seat belt…
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi there, Figmo. This seatbelt concern doesn’t sound like something we want you to experience with your Bronco. Should you need further assistance, please send us a DM with your VIN and the name and location of your Ford dealer and I'd be happy to look into how I can assist you on my end. To send a direct message, just click on our username and select "Send Direct Message".
Bronco Don
Don
Rialto, California
Tacoma 4x4
Mine has been doing this from new, I have 43,000 miles on now and hoping my extended warranty will cover this
Mad Martigan
Matt
Oklahoma
Fords (Bronco BadTrak, Expedition Timberline, Bronco Sport, Edge ST)
Mine has been doing this for about a year.
