Driver seat edge wear
ONEBronco
Keith
Omaha, NE
2022 Bronco
So, planning on keeping the Bronco for a while. Any recommendations of how to maintain the integrity of the outside edge of the drivers seat?
SHANUT
Craig
Hermann, MO
As stated above, it’s best to step up and over the edge of the seat when sitting down or getting out of the vehicle instead of sliding in and out of the seat. If you do that, it will last forever.
V1Rotate
Bryan
Brevard, NC
2022 Wildtrak
If you have the "leather-trimmed Vinyl" seats then the part you'd slide in on is pretty durable vinyl anyway so i wouldn't worry about it. Heck the "leather" parts are so cheap they still look brand new after 2 years of zero care in mine
2DR22Bronco
Chad
Seattle area
04Cobra, 95Cobra, 17Explorer, 22Bronco
You can order an extra seat bottom cover while they are still in production or look for one on eBay from a wrecked vehicle that is in good shape (will need to use your vin# to check and make sure the correct one when ordering). Chances are if you have heated seats you will be replacing the seat heater in the 4 to 6 year mark and would want to replace it with a new one anyhow. I bought 2 and was about $175 each for the MGV for my badlands.
Crabapple
Ontario
Ram Promaster City
Replace seat heaters in 4 yrs!!? Really! Is Ford quality that bad? I've had heated seats in several vehicles from Subarus to Rams, typically keep a vehicle for ~10 yrs and never had to replace a seat heater
A side step of some sort - keeps a lot of weight off the side as you get in and out
JT58Bronc
JT
Fl
2022 Bronco, 1987 Chevy Squarebody 4 X 4
As others have said I try real hard to lift myself on the seat rather than slide on it. I do it without running boards or steps too. I have to reach in, put my hand on the rear of the bottom seat cushion, lift my leg on the door sill and between pushing up with my leg and hand, push myself up on the seat. It works though.......and no running boards or steps for me- ever.
ChrisB351
Shreveport, LA
I have mgv seats and I slide in due height of the bronco. 36k miles and holding up a lot better than I had anticipated. The cushion does seem to be flattening a very slight bit compared to the passenger side but nothing Im worried about.
helifino16
Ron
Mount Sinai, NY (Long Island)
Carhartt makes great seat covers. You could go through several of those before getting to the expense of reupholstering the seat.
Sparkie
Massachusetts
Sold all my cars to buy the Heritage Bronco
I owned 2 different Ford Focus hatchbacks. Ten years later, the heated seats on both of them are capable of cooking my a$$ in February. So, I expect nothing less than 10 years with my new Bronco.
2DR22Bronco
Chad
Seattle area
in 10 years my ford explorer bottom heater went out twice on me. Once was under warranty and than was out again at about year 7. The top back heater has not went out oddly. I do live in a colder climate though and use them frequently.
tourproto
Portland, OR
2004 BMW 330i, 2022 Bronco BL 4DR
The seat heaters in my wife's 2013 Subby Outback still work fine. The seat heaters in my 2004 BMW 330i are also still going strong. As long as the Bronco's go bad in the first 8 years I don't care (extended warranty). I'll be ticked off if they die in 9 years :)
Cobrafang
Thomas
GA
Ford sells an ugly but functional neoprene seat covers.
