Door Drains or Problem?
vegetarianbarbarian
Ara
Novato, CA
2021 Ford Bronco 4dr
Brand new to the forum, just picked up my 4dr hardtop a couple of days ago which happens to coincide with actual rain in California. When I opened every door I noticed water draining out of these little cutouts in the lower part of the door. It seems like the water is being stored in the door. Is this intentional or a problem?
I can't wait for all the other quirks to show up, considering what I paid.
Ford Bronco Door Drains or Problem? bronco door
PWillette
Parrie
Maine
Hard to see in the picture but they appear to be factory drain holes working as designed. Unfortunately I have not yet received my Bronco to confirm.
Felix808
SRV CA
That is normal with most all vehicles. There are small drains in the doors because the window seals are far from watertight.
69BroncoX302
1969 U15, 2021 First Edition
Just make sure it doesn't get clogged with pine needles, happened in my 69 bronco and the door rusted inside out.
MayhemMike
Mercury
EVERY first generation that lived east of the Mississippi rotted out, pine needles or not.
j_anderson
Jason
Fort Wayne, IN
www.instagram.com
Def want to make sure the drains are clear. Good news is the door skin is aluminum, IIRC
BroncoAZ
Mitch
Aluminum door skins won’t rust. I would still try to keep the holes cleared out.
93_SVT_3503
JJ
BFE
2016 F150, 1967 Bronco U-14, 1993 Mustang Cobra
Those are weep holes for water drainage, my '16 F150 has the same thing. After a wash or rainy weather I always open the doors, make sure the holes are clear of debris and dirt, and give them a little shake. Otherwise the moisture will just sit inside the doors.
vegetarianbarbarian
vegetarianbarbarian
Ara
Novato, CA
Thanks All for the confirmation and fast responses. I feel like I'm just waiting for sh-t to go wrong with a brand new ride. Hopefully nothing does.
I'm going from a 2015 JKU Wrangler, which gets plenty of water inside.
