Does the jack lift the wheel?
Sonnyhe2002
Fl
Black diamond, model 3
I was changing the rear tire of the Bronco. But even at max setting of the jack, the wheel is still firmly planted to the ground. I have not jacked up suvs/trucks before.
Should the wheels be lifted off the ground like when I use a jack on a car?
( I didn't finish changing the tire as I dont want it to fall... I'm scared)
There is a video of how it looks:
Razorbak86
Northwest Arkansas
Ford Bronco, BMW R1150 GS
Wrong location. The jack point for the rear wheels is the rear axle tube.
Ford Bronco Does the jack lift the wheel? FB6F90F1-144F-4C7E-8340-20DD7949FE40
Ford Bronco Does the jack lift the wheel? F3425389-01B3-4DA0-B4BB-19D70DB84EF1
Desert_6G
Phoenix, AZ
Ranger
Look at the manual for the jack point. It shouldn't need to go that high. I'm sure Ford didn't supply a short scissor jack.
Ground_zero298
Scs michigan
That jack is sufficient if compressing the suspension. Where you have it let the suspension drop. Hence the tire on the ground. Like stated the rear axle will compress it.
That’s how high mine is just to get all 4 a inch off the ground lifting from the frame.
If under the axle you only have to go 4-6 inches to get off the tire off the ground. Should be lifting the wheel up, not the frame.
Ford Bronco Does the jack lift the wheel? B33224F2-9A0C-4159-8ECE-782D19FCF93A
Ground_zero298
Scs michigan
Also a regular jack and a couple jack stands will help with your confidence and make life easier. Good to stay safe when lifting.
Sonnyhe2002
Fl
Just to confirm, the rear axle is a cylindrical tube and don't have any flat surface that I see. I should put it on the round surface right?
DUSTYcazOREGON
Craig
It never hurts to have some of those square RV plastic jack pads on hand too. You can put those on the ground, then the jack to give you some more lift. Depending on the terrain, you may need them.
Ground_zero298
Scs michigan
Don’t mind the red on mine. It goes over the parts your going to see on yours. Just protection plates. The 4 circled areas are where I hand jack mine rear end up at. Use which ever one makes the best contact with the jack head.
And yes. Your are correct. The round tube is the axle.
If you see the jack start to tilt or the truck start sliding on the top of it (will start slowly walking, not just going to drop) Just lower and reset it. It happens.
Ford Bronco Does the jack lift the wheel? F9B070B3-2710-4AD3-9B19-D901019CACAC
Moto26
Tucson AZ
You probably should call for roadside assistance.
Harsh, but true - if this is a roadside emergency.
But it looks like you’re in the driveway? If so, carefully go over the manual and figure out exactly what to do. If possible, find a helper with some experience.
BostonSasquatch
Randy
Boston
Bronco Lux Badlands with hardtop and Sasquatch
We can $pend on all $orts of $tuff, like jack pads. I simply keep a few blocks of wood in the cargo storage bin (behind the tire tool bin). Very handy to 1)make sure I get the lift I need, 2) stabilize the procedure if I'm not on pavement, or 3) position my jack if I'm in a hollow or on uneven ground.
Ordinarily, I don't like scissor jacks, but a recent unpleasant discovery changed my mind. I was taking a flat off, and found that (ulp!) at my age (75) I could not heft the Goodyear Territory spare onto the lugs. Well, I'm in good shape otherwise, but I was in remote Utah, all alone. What I found was that the scissor jack allowed me to make micro adjustments up, down, up... until I had the spare, standing on the dirt road, even with the top lug. Once I could hang the spare on that top lug, I could wiggle the other five into place.
So yeah--that scissor jack did the trick. At least for me!
SPITmadFIRE
CA
First, an answer: yes. The rear axle is fully enclosed in that round tube. In the middle of the axle is the rear diff. Jack the truck up from the round axle tube itself.
Secondly, some advice. Slow down, take your time, use jack stands if you’re going under the car for even a second, and do not forget to set the parking brake before you jack the truck up. You should always jack the vehicle up on a level surface. If you have a manual, put it in gear before jacking it up as well. You don’t want that sucker rolling off the jack while you’re working on it.
LockedBronco
Frank
PA
1972 Bronco
No disrespect but the ( I didn't finish changing the tire as I dont want it to fall... I'm scared) says a lot. Especially the I'm scared part
Tarheel_Wes
Wesley
FJ
Re: #6 above.....was my Bronco supposed to come with a locking nut on the spare? Ive rotated my tires a couple of times since taking delivery...never noticed I needed a "key" to unlock a nut on the spare....
Solfive
NV
2008 JKUR
No shame in not feeling comfortable changing the tire, you did the safe thing by stopping and asking for help. While I think you’ve been given excellent advice so far if I were in your position I’d call a family member or friend and observe them this time. Maybe even practice doing it yourself under their guidance. The old saying “you don’t know what you don’t know” can be dangerous in situations like this.
