Does the Bronco have heated side mirrors?
PullMeOverRed22
Orange County, CA
2022 Wildtrak
it keeps the cabin at the temp you have set on the dials. it also sends the air out all the vents instead of just the front, or floor etc. (Climate control)
So during the use, you will hear the fan speed change, and even sometimes the AC will turn on if it gets to hot for you set temp. the 3 levels are fan speed auto settings.
i use the lowest auto setting all the time over setting where vents to use.
Thanks!
timhood
Tim
Several
As far as I know, just the temperature knobs. The 21s show the temp and have an aluminum bezel on the knobs. Yours don’t have the same bezel.
They also changed the orientation of the parking brake switch. It seems over-eager peopler were completely pulling it off when they thought it was a mechanical lever rather than an electric switch.
