Does the Bronco have heated side mirrors?
mybikeisred
Paul
Carmel, CA
F250 Powerstroke, Grand Cherokee
Out of curiosity, what are the interior differences between a '21 and a '22? I'd assume nothing changes, but since you said obviously, now I'm really curious.
As far as I know, just the temperature knobs. The 21s show the temp and have an aluminum bezel on the knobs. Yours don’t have the same bezel.
mikeeshim
Los Angeles, CA
MBZ E350, supposed daily driver
Looks like there are little screens in there. Just not on.
Correct, the desired temp shows inside the knobs. Did they get rid of that for '22? I use that temp info more than the on screen temp info.
AceGoliath
Charles
IL
21 Bronco OBX SAS , 22 Maverick XLT, 10 Fusion SE
2021 Driver and Passenger Temperature knobs have a display with the the degree readout on the actual knob. For 2022, due to the chip shortage, the knobs just display a thermometer and the temperature readout is up on the touch screen.
https://www.bronco6g.com/forum/thre...ure-setting-displayed-on-control-knobs.34131/
mikeeshim
Los Angeles, CA
Mine shows the temp in the bezels, but they are rubberized knobs with an aluminum frame behind the knobs. I took delivery in Oct of 21, so maybe they ran out of aluminum bezels by the time mine was built?
Ford Bronco Does the Bronco have heated side mirrors? 220622_115022759
AceGoliath
Charles
IL
Mine is the same type of knob/bezel. 2021 OBX, LUX, Built 9/2/21. I think the photo going around with the more aluminum bezel may just be a preproduction model.
Looks like a press photo and has an illuminated PRNDM - which also isn't a thing:
Ford Bronco Does the Bronco have heated side mirrors? 1655924962452
mikeeshim
Los Angeles, CA
That does add a nice touch of elegance, doesn't it?
Doesn't fit in a Bronco, though.
ATLBronco75
Tom
Atlanta GA
2.7 Badlands
This is an early 21 Badlands Lux so that metal bezel is likely only in the press photos.
Ford Bronco Does the Bronco have heated side mirrors? 0E0BC6C7-62DB-4930-92D8-E1AD27910EEA
mybikeisred
Paul
Carmel, CA
Well, I feel a tiny bit better now. I only got robbed of the temp display, not the fancy bezel.
bellboyfab
So-cal
‘22Bronco ‘93 C3500
The side mirrors heater is tied to the rear defrost, they activate on the same button only the soft tops actually display the heated mirrors logo on the button, the hard tops show rear defrost.
cbrenthus
Western PA
'22 BadSquatch, '02 T/A
21-23 have electric heated mirrors. 24 and up will have manual heated mirrors due to Ford limiting luxury items. To operate the manual heated mirrors, you roll the window down, put your mouth to the mirror, and then go "haaaaaaawww" ;)
ram
Ram
Madison, WI
FORD BRONCO- 4 DR
I checked my 2023 Bronco with lux package, it does not have any control button/switch for heated mirrors. I too was wondering whether the 2023 models come with heated mirrors or not.
HotLap
Bradley
CA Central Coast
2023 Bronco, 2024 HD Street Glide & 2019 Yamaha XSR900
If you have the hard top they're likely ingetrated into the rear window defrost button. My 2018 Raptor is the same way.
ram
Ram
Madison, WI
FORD BRONCO- 4 DR
Thanks. Mine is a hardtop. And I do see the rear defrost button. Appreciate the response.
PullMeOverRed22
Orange County, CA
2022 Wildtrak
ok, stupid question, but I have completely ignored that auto button in the middle. Is that for an auto fan speed?
Combustion_King
Derek
MA
Yes
it keeps the cabin at the temp you have set on the dials. it also sends the air out all the vents instead of just the front, or floor etc. (Climate control)
So during the use, you will hear the fan speed change, and even sometimes the AC will turn on if it gets to hot for you set temp. the 3 levels are fan speed auto settings.
i use the lowest auto setting all the time over setting where vents to use.
