Does rear diff have a reusable gasket?
Happy
Jerry
Missouri
CJ5, Wagoneer
Does the (SAS M220 with 4.7 ) rear differential cover have a reusable gasket?
flip
Phil
IN
www.ruxerparts.com
Fords
  1. NOTE: Make sure to note the position of the gasket prior to removal.
    NOTE: Make sure the component is seated at correct position.
    NOTE: The gasket is to be reused unless damaged.
    Remove the gasket.
Ford Bronco Does rear diff have a reusable gasket? video
Ford Bronco Does rear diff have a reusable gasket? Hel
  1. NOTE: Use care when cleaning the differential housing and its cover gasket mating surfaces.
    Clean the gasket mating surface of the axle and the differential housing cover.
Installation
rhymeswithbronco
Stewart
Spokane, WA
2023 2-door 2.7 Badlands
Doubtful since it looks like a stamped steel cover and most people won't be opening it regularly. Pretty much any Dana 44 gasket should fit however.
Edit: I digress, looks like it might be. However, reusable gaskets are dependent on whether the last guy to touch it properly torqued the fasteners. I would splurge on a new Fel-Pro and some Permatex if it were me--cheap insurance.
Happy
Happy
Jerry
Missouri
CJ5, Wagoneer
Thank you!
But still a little confused with 2 different answers.
My last 2 ford had reusable gaskets. But does not mean the Bronco does.
Exomodo
Ryan
Marquette, MI
Ranger
This is not correct, the Advantek 44 is much different than the legacy Dana 44. It is colloquially known as the D44A or Advantek 44, and is the same as a Jeep Wrangler JL.
Happy
Happy
Jerry
Missouri
CJ5, Wagoneer
I heard that the "new" Jeep M220 was an updated D44 and had re-usable gasket.
Is the Advantek 44 the update version?
Also, do M220 rears come in different ratios?
I will have gasket juice if I mess up the existing gasket.
Exomodo
Ryan
Marquette, MI
Ranger
The Dana 44 and the Dana Advantek44 share no components, and the 44A is much stronger, in the footprint of the D44 with the capacity of the D60.
See:
rhymeswithbronco
Stewart
Spokane, WA
OP- I based my answer off incorrect info I didn't verify first, my apologies, and thank you @Exomodo for setting me straight. Maybe a gasket spec'ed for a '18-19 Wrangler would fit? I just don't see the point in messing with a reusable gasket in this application.
Exomodo
Ryan
Marquette, MI
Ranger
Spicer sells a Nodular cover, the same as the Ford motorsport cover, for half as much.
Part numbers
10040651 in Grey
10053468 in Blue
That is what led me down this rabbit hole in the first place. Unfortunately, this cover doesn't have the drain provision similar covers from Dana Spicer do, negating this advantage, unless you drill and tap it yourself...
If you find yourself fording water or in mud, changing the fluid is a reason for a reusable gasket or a drain plug lid.
Raptor911
Raptor911
Broadlands, VA
I assume the stock cover does not have a drain bolt?
The Raptor does not have an oem drain bolt so I installed an aftermarket cover which has a drain bolt.
This is on my 2019 Raptor (https://ballisticfabrication.com/)
Ford Bronco Does rear diff have a reusable gasket? 1640798161703
    Remove the gasket.
Installation
flip
Phil
IN
www.ruxerparts.com
Fords
Correct, no drain. If they had a posted service interval I could see a factory installed plug. Guess they figure it's one less opportunity for the quickie lubes to upsell you.
Happy
Happy
Jerry
Missouri
CJ5, Wagoneer
Rhymes ....I'm learning as I go. Your post spurred others to post! All good.
I have old ways and want to do a differential fluid drain around 2-3,000 miles.
I've done this for most of my vehicles and always amazed at the silver junk that comes out.
May not make a hoot of difference to help the differential but makes me feel warm and fuzzy.
or is that just my long handles?
Tonka Bronka
Duncansville
F350, V60 Polestar, 900SS, K1300S, RnineT Racer
I just ordered Amsoil Severe Gear 75W-90 for my diffs. I was going to suck out the old fluid and fill but I would rather take it apart if there is a gasket available. My 2007 Super Duty had no gaskets and ended up installing Mag Hitech covers with O-rings. I had trouble getting the stock cover to seal with just Permetex.
Happy
Happy
Jerry
Missouri
CJ5, Wagoneer
Amsoil has successfully advertised to me also. Been using their gear oil for years.
I used to scrape cork gaskets off and then used gasket juice. Once I knew about resuable gaskets, I would rather not go back to any other kind.
Tonka Bronka
Duncansville
Their products are exceptional. Do we know the answer yet? Our member flip will know for sure.
