Does Ford sell any performance intakes for the 2.3?
Kboyts
Ohio
2025 big bend
I have a bank of ford reward points burning a hole in my pocket. Just bought a flowmaster exhaust and looking for an intake. Does Ford offer anything I could use my points on? Ive searched but couldnt find one. Although I have found numerous other items via posted links that I was unable to find via search.
Not that I’m aware of. Just ProCal
Many aftermarket ones though
Kboyts
Kboyts
Ohio
2025 big bend
Ive been eyeballin a few aftermarket ones but was hoping to be able to use all these damn ford points to basically get one free. Also just though about the fact that since they redid the 25 2.3 my options are probably limited even more.
UncleBrad
Brad
Indiana
2024 Bronco 2-DR Manual
I too went with a Flowmaster (axle-back American Thunder) and at the same time installed the K&N complete cold air intake. I didn't find one from Ford (and the bazillion Ford points I had accumulated were only good for a couple of oil changes). The K&N works great, but it's a hard install, poorly-made and over-priced. And that filter has an alarming smell that lasts for quite a while (especially under boost). If I had to do it again, I would not do K&N.
Smocaine
DFW, TX
Cervelo Caledonia
There's a Roush intake - that's probably about as close as you'll get to a Ford intake, but it's expensive and not available for Ford points.
Kboyts
Kboyts
Ohio
2025 big bend
Yeah not really concerned about the manufacturer as they all most perform about the same, just want to use the stack of ford points on something cool.
Bill K
Bill
Allen, TX
Ford Bronco Big Bend 2 Door
Can't remember the name of the system she installed for an intake, but if you search on Buckle Up Buttercup she's got a review on one she really liked. She had another installed, but it was giving her alerts for some issue. She replaced it with the current one (which had easy access to the filter element for replacement) and the alerts went away and she was pretty happy with it. I've found her videos to be good for some of the work I've done on my Bronco...
UncleBrad
Brad
Indiana
I get most my stuff from Buckle Up. Prices are normally competitive, super fast shipment and great attitude. On the web site, currently the price listing on when doing the search is not matching up with the actual price when the product detail is opened up, but the Corsa box (just the box and filter) is $650 as of this writing.
https://buckleupoffroad.com/product...ir-intake-with-donaldson-powercore-dry-filter
danielamos
daniel
michigan
Save money and just order from Temu. They offer the same products as Buckle Up Buttercup, just cheaper.
23OBX2.7
AB Canada
2023 Bronco
Don't waste your money of aftermarket intake there is zero benefit already an excellent CAI. Same with filters. It's all snake oil.
A Radium alloy baffle and dirty side catch can is a good investment on pre '25.. I believe they are avail for Bronco 2.3.
May also want to check your low pressure fuel sensor at the rear top of engine see if it's the most current part #.
May want a Ford Performance bigger turbo....
danielamos
daniel
michigan
Agreed. Buckle Up Buttercup’s products are a waste of time.
CarmeloS
Carmelo
Central Jersey
‘21 2dr Bronco, '25 GR86 w/Performance Pack
No, just no. Get a Volant or Corsa, cheaper and a lot better
heavyD
Calgary, Alberta
2025 Badlands 2-Door
There is zero performance benefit but they are noise makers and engine bling for people that care about that stuff. I don't but some people like to see shiny stuff when they open their hood.
