Do you really need rear locking differental?
mybikeisred
Paul
Carmel, CA
F250 Powerstroke, Grand Cherokee
If you've never wheeled a locked rig, you don't think you need it. If you have wheeled a locked rig, you absolutely know you do need it.
Yep. Once you have used them, you can’t go back. Even in situations where you can get over an obstacle without a locker, it will be much smoother if you do have one. You don’t need to romp on the gas and use momentum to thrash your way up the trail, you can take it slow and easy. Romping on the gas to clear an obstacle is fun and all, but if that’s what you want to do, get an old beater truck to thrash around.
okbob
North of the Red
71' u15, 66' u14, 66' u14
I'm not sure anyone has ever had lockers and wished they didn't......
I'm not sure anyone has ever "walked away" from buying a vehicle because it had lockers.....
I'm sure you'll be fine without lockers until you need them........
I can 100% be certain that it's cheaper to buy it with lockers rather than add them later.....
Get the lockers :)
BroncoAZ
Mitch
Yes. There will be at least one time in your Bronco’s life that the locker saves you from having to call for help, money well spent.
Vcastag
Vince
Cave Springs, AR
2022 Bronco Outer Banks 2.7
I ordered my 2022 OBX 2.7 liter with the Rear locker. I never used the front locker when I had them in 2 trucks and I will likely never do SERIOUS rock crawling or any higher than a 5. I know the rear locker will do the trick .
I’ve since upgraded to Eibach pro truck coilovers with a 3 “ lift, 35’s and BDS UCAs and Rear lowers. I think I’m set for 99.9% of what I can get myself into.
