Do you Like taking the doors off?
wunce1
Nathaniel B
Rushville, IL
www.tat2dsqrl.com
If you are like me and like to remove your doors, and you absolutely hate the locator pin that Ford provided in the tool kit.
Click the link below to watch this YouTube video for the EZ4X4 Door alignment pins.
This is a product that I purchased and knew right away that I would like it.
I reached out to EZ4X4 and got a code that you can use if you are also interested in getting your own set Click the link below to shop and
use code: SQRL
Ford Bronco Do you Like taking the doors off? 462548609_890286409898557_296056761960917388_n
https://www.ez4x4.com/?ref=SQRL
adcam
Mando
2025 Stroppe
That looks like a newer version of what they used to offer.
jebo_4jc
MO
2015 Explorer, 2023 BadSquatch
Interesting. I actually never used the OEM guide posts. But it's a real PITN to line them up, that's for sure.
But at $63 after coupon for the 4 door kit....I'm not sure I take the doors off often enough to make that worthwhile.
WarthogJr
'21 Bronco Black Diamond
use code: SQRL
How long have you been selling these?
1st 75th ranger
jeffrey
nj
use code: SQRL
i take mine on and off often more so then taking the roof off lol
cheers
Southside_Ray
Ray
Iowa
2014 Ford Fusion
This is identical to a pair I see on Amazon. I actually bent my OEM guide pin So this is a good idea for me. I may purchase with the discount that is offered. I like the roof removal tool on this website as well. Much cheaper than top lift and folds up smaller.
Philvis77
Phil
2000 Jeep Cherokee
Do these make aligning the top pins easier? Those are the ones i hate with a passion.
darinhouston
Darin
U.S.
Bronco, Jeep Wrangler, Bronco Sport, Pallisade
I'm considering making small plastic guide plates (probably 3d printed) to abut the frame and provide a guide notch to place the door edge in and push against and have a lever point to better control the door as you slide down so you aren't hovering while lowering onto pin. Before I spend the time to measure out all the angles, has anyone seen anything like this?
BroncoBilly24
Bill
Vancouver, WA
2024 Ford Bronco
I picked up my Bronco in April and didn't take the doors off this summer. I had the tops of for a couple weeks, but it was so hot here in the PNW that it wasn't comfortable.
I had a 2012 Jeep JK for 10 years and took the top and doors of every summer and loved it. It was a 2 door and the doors were heavy and difficult to get off and on and a challenge to store.
From everything I've seen, the Bronco doors are much easier to handle. I have bags for the front and back, and the instructions tell me to slip the bags on first, then take of the doors. reverse the process to put them on.
Looking forward to the first time driving with all 4 doors off!
PrepVet
North Central WI
A bunch.
I've owned many Jeeps prior to my Bronco and I have never once taken my doors off nor felt the need to. 🤷
Johnny Mo
Westchester County, NY
teachu2shoot.com
M-B GLE53 AMG, Ducati XDiavel, Jeep WK GC x3
They are much easier to remove than they are to put back on.
USMCAg
Brazos County, Texas
2016 F-150
I take the doors off every chance I get. Even with the factory guide pin it doesn't take long to put them back on.
