Do (mostly) no issues Broncos exist?
BadBronco23
Austin
AL
2023 Ford Bronco Badlands
I’ve only had my 23 badlands for about 4 months and put a little over 4K miles on it and haven’t had any major issues. Mines got the 2.7, it was shifting kinda hard occasionally the first 2k miles or so and would make a loud clunk noise when putting it in gear if I didn’t let it warm up a little first. I just assumed since it was new it needed to be broke in, and since I’ve put more miles on it, it doesn’t do either of those things anymore.
Arokcrwlr
Kraig
US - Alabama
2014 F150, 2014 Focus, 1973 Bronco
23 WT, 30k miles...front pinion seal and pass side CV axle replaced due to torn boot. Otherwise, no issues.
ETA: I did upgrade the rear DS with an Adams 1350 unit because of a torn boot on the factory one.
BearPatrol
23 Bronco
Had mine for a little over a year, at 40k+ miles, daily driver, wheeling it a fair amount in the summer, lots of snowy mountain roads in the winter. Only issues I've had are the occasional connectivity issues with my phone, which plugging it in resolves. Yeah, I'll complain about all the reminder alerts that you have to hit OK for... But I haven't had any real problems at all. Trust levels are currently pretty high. This thing rips.
Rumbloki
Alton
ATX/PCB
ZR2, 1973 Mach 1
15 months. 16k miles, no issues
adam1991
VW GTI (2)
Depends on your definition of “issue”
apparently "I don't like where the emergency flasher button is, I have to reach over two more inches than I think I should, frankly it's in a spot where no driver could possibly find it" is now, in today's world, a "serious issue" that we all must acknowledge and embrace simply because someone said so.
WilVis
Northern Utah
Ford Bronco
My 2023 2.3l Basesquatch needed a new transmission at 200 miles, which freaked me out. Dealer and Ford were good fixing it with a free extended warranty.
Now 17,000 miles with no issues except for occasional infotainment screen glitches. I’ll keep it until the kids want it in 10 years.
Unless you buy late in a vehicle life cycle when most recalls/issues have been worked through, I think reliability is fairly equivalent for the major brands. Even Toyota as of late has been taking hits. I’d much rather have a Ford turbo engine than a Toyota turbo at this stage in the game.
ttt123
brian
Lapeer mi.
Bronco, GMC evolution, Chevy corvette
hmm my 24 just crossed 2k miles and i haven't had any issues 😇 lol
Every person has their pet peeves. Mine switches between floppy windows in the summer and cold feet in the winter.
Karsa
Calgary, AB.
‘24 Bronco Badlands
Ohhh, the okay’s! It’s a little needy to be sure! Hahaha
Imaginary Friend
Southern MN
A passel of Fords and a Jeep JL Rubi
The forums do not represent the big picture--they represent, by and large, only those with problems and those who mod (and then have problems). Yes, plenty of no-problem Broncos exist.
Fact.
However, trending common issues had by some here on the board, as well as a not-so-great experience with my '19 F150, have kept me from buying a Bronco. Not to mention, my '23 JL Rubi has been fantastic and I can't justify the (substantial) added cost to move to the equivalent Bronco from it (and I ordered it when I couldn't order the base Bronco I wanted to start with).
Montana Bronco
Montana
Chevy
ZERO ISSUES with my 2023 Base, 2-door with a manual transmission.
Proof that Bronco’s are built by robots, not humans. My build date was 4/20 and Michigan has legal weed, so you know the workers were hella smoked up. Still absolutely zero problems.
Pic from the day I picked it up in Iowa from Granger. First BASE ever made in Azure Gray. Super rare and valuable. No lowballers, I know what I got.
Ford Bronco Do (mostly) no issues Broncos exist? IMG_5992
PowerBronco
Steven
23 Bronco Badlands, 07 FJ Cruiser, 04 WRX STI
Loving my '23 badlands that I have owned for 16 months now. Only some of the usual minor complaints, but no problems.
timhood
Tim
Several
New owner here. Bought a new Big Bend 2.3L, manual trans, soft top a couple weekends ago. Have put almost 500 miles on it (5 on the odo when I test drove it) so far and I love it! Everything works as it should. The engine is smooth, the trans is smooth, and carplay even stays connected to my iphone.
I lurked here on the forum for a month or so before I bought the Bronco and almost decided not to buy one due to the posts on this forum. I know folks are more likely to post when they have issues, but are any of you driving what has been a mostly issues free Bronco? It's hard to tell if the good ones outnumber the problems some times.
Here's a pic from our first weekend of driving around the Texas hill country backroads.
I passed 20K miles while on an off-road trip earlier this month. I've done 8 major road trips and at least two dozen off-road day trips. The only issue we've had so far was the hood latch sensor that would report the hood was not closed and occasionally set off the alarm. That affected a random number of early Broncos, so wouldn't apply to yours. It was replaced under warranty.
bsmith922
Rancho Cucamonga, CA
2023 Bronco Raptor, 2023 Tesla Model Y
I first had a 21 Badlands that only had 1 minor issue - not enough A/C coolant filled at the factory.
My 23 Bronco Raptor has had zero issues (unless you count Apple Car Play funkiness once in a while) - had it since July 23, almost 19k miles so far.
timhood
Tim
Several
That's right up there with, "I don't want to bother to learn how stuff works and consider it a major problem if it doesn't work the way I guessed it should." 😄
