Do I need hard shackles with this set-up?
U725Bronco
NorCal
North7
North Texas
SUV
I just ordered 2 of these soft shackles:
https://www.bubbarope.com/gator-jaws-synthetic-shackles/gator-jaw-pro-synthetic-shackle
and this kinetic rope:
https://www.bubbarope.com/jeeps-and-trucks/bubba-rope-30-foot
Should I also get hard shackles for the front bumper or do the soft shackles work with no downsides on the front modular bumper recovery points?
Thanks!
You will cut the soft shackles on the sharp edges of the Shackle pin holes, buy the hard ones.
D-ring shackle mount for the sharpe hole edge detail example only.
Ford Bronco Do I need hard shackles with this set-up? mb2028-view-2
Vantcrst
CA
92 Ford F-150, Mercedes 4x4 Sprinter Van,
Don’t have my bronco so don’t know how rounded the holes in the recovery points are. If they are rounded with no sharp edges there is no need for D shackles. That is assuming of course that the hole in your recovery point is large enough to put the soft shakle through.
kodiakisland
Arkansas
Soft are all you need. Lighter and stronger, but doesn't have the cool factor look.
I've got a couple stuffed in the jack storage area.
Vantcrst
CA
He is correct if the recovery points have sharp edges like the above then get the D shackles. But take a look before you buy. a lot of manufacturers of off-road equipment are starting to design recovery gear with soft shackles in mind so you will see a lot more rounded edges on recovery points etc.
kodiakisland
Arkansas
It only takes a few minutes to break the edge if they do have a sharp edge. I'd rather have the soft shackles from a safety standpoint, but those hard shackles sure look good.
North7
North Texas
SUV
I just found a good shot, looks like the champhered the edges.
Ford Bronco Do I need hard shackles with this set-up? 1628620902724
Vantcrst
CA
U725Bronco
U725Bronco
NorCal
I just went out to look at the recovery points and they do seem somewhat sharp. I suppose I'll use the soft shackles for the rear bumper recovery points and pick up the SITH or the Gear America shackles for the front. Thanks everyone....Happy New Year's Eve!
Ford Bronco Do I need hard shackles with this set-up? IMG_8820
kodiakisland
Arkansas
Vantcrst
CA
I would assume that opening behind the shackle pin hole is designed to be used with a soft shackle. Doesn’t that opening go all the way through? If so that has to be what it is for.
U725Bronco
U725Bronco
NorCal
It does go through and I didn't even think of it, but see the post above. Thanks!
Vantcrst
CA
