DIY - remote engage/disengage Rough Country Hidden Winch lever
Bellime
Keith
2022 Ford Bronco
FYI - after logging in Montana I found the Rough Country Hidden Winch performed like a champ. It pulled logs of a couple thousand pounds with no problem, but for lacking feature - access to the Engage/Disengage lever. Spooling it out via the motor is way too slow and could mean the difference in a successful rescue as time is everything in emergencies.
I have successfully developed several solutions that now provide a method of using the Engage/Disengage lever from the front of the bumper
Ford Bronco DIY - remote engage/disengage Rough Country Hidden Winch lever IMG_1792
this solution doesn’t require opening the engine hood or dismantle anything while it won’t be harmed when 4 wheeling. I have some other designs that I am working on as alternatives but they all end up with the same outcome. Now I just need a lever that fits the 1/4” hex fitting instead of the ratchet.
Dubsesd
Andrew
CT
04 Ford F-150, 06 Roush Mustang
Interested for sure!
ScLeCo
Springfield
Charger Hellcat
How are you going to do that when you're buried in mud or up against rocks?
Bellime
Bellime
Keith
2022 Ford Bronco
Well, if your buried that far, then a permanently attached lever is the only solution, so you can blindly reach down in the muck to flip it.
Bellime
Bellime
Keith
2022 Ford Bronco
There was another approach I scoped out, but it requires opening the hood and drilling a hole in the cross frame member behind the radiator
Greasyfingers429
Adam
RI
VW Jetta TDI, Range Rover Sport Td6
As clean of an install as the hidden mount is, these drawbacks are what have kept me waiting to see what else comes out. Glad to see you sharing what you have come up with.
Even with the draft design I made for a front hitch receiver for my removable winch, I ran into access issues for the hitch pin if I buried it under the front skid plate.
One suggestion I have for you is to lock your lever from rattling out of the desired position. And provide a visual indicator when it’s in the locked/unlocked positions.
Bellime
Bellime
Keith
2022 Ford Bronco
Still in testing before I make a front mount to hold the tip and then potentially a fixed lever.
Bellime
Bellime
Keith
2022 Ford Bronco
After final testing I have finalized the installation. All parts are off the shelf with modifications.
The final assembly is here
Ford Bronco DIY - remote engage/disengage Rough Country Hidden Winch lever IMG_1803
installed at the winch
Ford Bronco DIY - remote engage/disengage Rough Country Hidden Winch lever IMG_1804
with the bumper on
Ford Bronco DIY - remote engage/disengage Rough Country Hidden Winch lever IMG_1806
with the modified aluminum ratchet it stays tucked behind the bumper
Canyon Coolers
Flagstaff
canyoncoolers.com
73 Bronco, Dodge 2500, Sprinter Van
Are you publishing your notes on this beauty or selling it ? I have to tear into my hidden winch this Saturday and replace the controller.
Ford Bronco DIY - remote engage/disengage Rough Country Hidden Winch lever 20230614_151122
Bellime
Bellime
Keith
2022 Ford Bronco
RC didn’t seem interested in a solution.
JMacBadlands
West Chester, PA
2022 Bronco
with the bumper on
This seems to be the best option I have seen and I am copying this. I am just having trouble with the connection from the winch to the opening on the 90 degree adapter. What did you use or modify for get that fit?
Bellime
Bellime
Keith
2022 Ford Bronco
A Dremel tool.
Bellime
Bellime
Keith
2022 Ford Bronco
Interesting you just now finding this. Mine is still functional, but the material is rusting. The idea and design works, the material sucks….. more research…..
JMacBadlands
West Chester, PA
2022 Bronco
I was thinking the same thing with the material the adapter is made of. I was going to look into if I could take off and put on just when I'm wheeling or spray it down with rustoleum before install.
