DIY AMP Research PowerStep installation tips.
GTTom
Tom
New Hampshire
2023 Bronco Wildtrak
Having installed AMP PowerStep Smart Series running boards on my Bronco here are some tips to make your install go smoother and hopefully quicker. I made the mistakes so you don't have to ;).
The large hex flange bolts for mounting the motor linkage and idler linkages are pre-coated with a thread locker. The consistency reminds me of plumbers dope that has dried to a flexible semi-hard paste. I found that tightening the bolts took extreme effort that made the install difficult with hand ratchets. I started with a 3/8” racket and then moved up to a 1/2” drive ratchet. Still difficult. Particularly the bottom front bolt which requires a racketing wrench to reach inside the idler assembly to tighten the bolt. I finally removed the brackets and used my power impact gun to run the bolts all the way in and then out of the holes of the under body. This removed the thread locker making the bolt tightening much easier. Note I did use my own LocTite blue thread lock sealer on the bolts for assembly. Do not skip this part. You do not want the bolts to loosen later.
Step #2 says to snug up the bolts but do not torque. I did this the first time around. Having to realign the drivers side later, I found leaving the bolts loose enough to rattle the bracket back and forth with your hand instead of snugging the bolts worked better when moving on to the torque phase.
FOLLOW STEP #4 TORQUE SEQUENCE EXACTLY! It does make a difference! The proper sequence will save time later when you don’t have to redo a step because of binding.
They don't mention it in the instructions but on my 2023 Wildtrak the rear of the step hits the rear wheel front splash guard. I had to trim both sides for the step to clear when retracted. You could also probably just trim the back of the step an inch or so to clear the splash guard?
When installing the running board lights you do not have to drill a hole in the pinch weld seam. Use the existing holes. I used the rear most hole for the back door. I used the 2nd hole from the front for the front door. Grab some rubber grommets from the hardware store and use these in the holes before running the wires through.
For wiring, Step #16 says to use the 2 purple wires. THERE ARE NO PURPLE WIRES! AMP changed the wiring harness to 1 YELLOW wire. The yellow wire was sticking out of the drivers side harness almost at the end directly below where the divers seat is located. Open the split loom conduit in the engine bay area and just pull the yellow wire out of the loom. You only need a foot or two to reach inside the drivers footwell. You can cut the rest off. Run the yellow wire through the firewall grommet as they directed for the purple wire.
The OBD plug provided from AMP has 3 wires, a yellow, blue and white wire. The yellow wire from the wire harness connects to the yellow OBD wire. The blue and white OBD plug wires get connected to the Factory Can Wiring exactly as the instructions state. The Posi-tap wire connectors provided for the CAN wires work but be careful not to drop the freaken little caps. I put a rag under the CAN wires to prevent losing one behind the kick panel if you drop it. You will drop one…
Installing the electric motors to the linkage assembly is not hard but the mounting bolts toward the frame on the inside is extremely difficult to reach. I have a pretty good tool collection and tried a bunch of different tools but a quality ratchet wrench moves just enough to eventually tighten the inside bolt. The cheap little plastic push clips that hold the motor cover in place are easy to break or lose. I went to the hardware store and picked up some plastic retainer clips.
On a final note my drivers side step did not retract evenly along the rocker panel. The front was hanging lower than the rear of the step. I took the step off and redid it following the torque sequence exactly. The step did work more smoothly but still sagged more at them front than the rear. I ended up putting a washer under the front lower idler linkage mounting bolt. The washer was added at the correct point during the torquing sequence and checked to make sure there was no binding in the movement. This worked perfect and the step now lines up evenly.
Total time for my install (making mistakes and redoing some of the above steps) was 6 hours for mounting and wiring. Then another 2 hours realigning the drivers side step a second time because the step was lower at the front than the rear when retracted.
Ford Bronco DIY  AMP Research PowerStep installation tips. 93DC0423-102F-43EF-BBF6-BD56883D3C66_1_201_a
Ford Bronco DIY  AMP Research PowerStep installation tips. 188CBC2C-BA83-4522-AFC9-A9EB5D230D7C_1_201_a
Ford Bronco DIY  AMP Research PowerStep installation tips. BDD5DB21-E40B-426C-BBC2-5A8E59EAACE3
Ford Bronco DIY  AMP Research PowerStep installation tips. 39202EAF-98BA-47CE-8D7F-F6B1A20D6AF6
Ford Bronco DIY  AMP Research PowerStep installation tips. A4CEB7B7-FB89-4E17-9FD7-1644A7414EB6
Ford Bronco DIY  AMP Research PowerStep installation tips. 3ED38E76-A787-4B7E-BEA9-82B45FE9DF8D_1_201_a
Ford Bronco DIY  AMP Research PowerStep installation tips. 9919AC2A-5B31-4AE5-80DB-5C4BD10F08A9
** Edited to add pics of trimming the rear wheel front splash guard.
capn00
Yardley, PA
2023 Bronco Heritage, 2018 GX460
Great write up, I am bookmarking this for when I eventually grab the AMP steps.
Thanks for posting
GTTom
GTTom
Tom
New Hampshire
Thanks for posting
You will like the AMP running boards! Absolutely no issues since install. I really like the Smart Step option. I use the app to lower the steps when I drive into the car wash so the prep guys can spray the steps before going through. Got the car wash guys trained. Now they wait for me to lower the steps before they send me through:). (Obviously I retract the steps before going through.)
Since the install I had knee replacement surgery. These steps are awesome allowing me to get in and out of the car more easily. Hopefully they will save you some time. I added some additional photos of trimming the splash guard.
capn00
Yardley, PA
Alright, finally got done with round 2/3 on installing the positaps. The only positive I can say about that part, it gets easier the more you have to do it, and now the steps are working.
I tried to follow the installation steps as closely as possible using your advice among others. I was certain everything was installed correctly. Plugged in the fuse, and the steps retracted perfectly. I was pretty excited. Then, I started opening doors, and nothing :mad:.
Tried troubleshooting what I could, all connections seemed tight; unplugged control module, unplugged fuse, unplugged and check motor plugs, etc. nothing. Finally got on the phone with Amp Research after taking some photos and videos, and they regretted to tell me they were almost certain there was an issue with the positap connection where the blue and white wires connect. They said sometimes, it is as easy as pulling the blue and white wires and stripping back a little more insulation, but they were certain that was the issue. So, I begrudgingly went back out to work on it.
What I discovered is that the actual tap side (black) on the small positap that was supposed to pierce the factory wire had simply scraped the edge of the insulation and didn't piece the wire. I should have been able to tell becuase the connection didn't look pefectly straight. So I went ahead and redid both the purple/orange and grey/orange connections since I was already down there. Okay, hopefully that works. But, then I couldn't get the other end of the positap to thread properly for the white wire connection to the plug. I was about to give in, order some extra positaps, and try later in the week when I figured out I put the damn center section on backwards since my fingers were damn near frozen at this point. So, another reset on the tap install and 10 minutes later, I finally have working steps.
But, of course now I am having the typical misalignment on the drivers side. It is a little bizarre because they were perfectly flush when I first gave them power and they retracted, but now that I had to rewire the vehicle connection I am getting that slight sag in the front of the drivers step. I am going to give it a couple of days, and hopefully pull it into the garage later this week to try to adjust the brackets one last time. Even when they retract, I can easily with almost no effort, push the front of the step into alignment, and once there, they stay and I can't pull them back down. Oh well, getting closer by the day.
If anyone reads all this, I apologize! I just had to vent somewhere and my wife is tired of hearing me cussing in the driveway trying to get these tiny ass positaps working...
Ford Bronco DIY  AMP Research PowerStep installation tips. IMG_6883
Ford Bronco DIY  AMP Research PowerStep installation tips. IMG_6884
Ford Bronco DIY  AMP Research PowerStep installation tips. IMG_6876
BigHoof
PA
Ram 2500
Sorry to hear you are having so much trouble. The Posi Taps were a PITA. I had checked the alignment / movement before installing the motors.
capn00
Yardley, PA
Yeah, I had checked the movement as well before installing the motors, and they retracted properly when given power the first time. I'll get them sorted out, just taking some time...
HP11
New Hampshire
2013 Boss 302 (sold) , 2023 Ford Bronco WildTrak
Read every word and thanks for sharing your experience as it will help me once I get around to installing these steps. Beautiful Bronco you have... I love the Cactus 4-door Heritage!
GTTom
GTTom
Tom
New Hampshire
Sorry you had so much trouble with the install. I also hate those Posi Taps. I dropped the damn caps at least twice. There‘s got to be a better solution. Maybe a type of tap the can be crimped instead of a two piece cap and screw. I have plenty of experience wiring cars but never used Posi Taps before. I figured they were something special required for BUS CAN connections.
GTTom
GTTom
Tom
New Hampshire
If after you redo the alignment sequence and still have a problem with the front being lower maybe consider using washers to shim the front linkage. I spoke with AMP and they actually have wedge shaped shims they can send to help with alignment. That might be a better solution. I didn’t request them because I didn’t want to wait another week or two to get the parts because I had knee replacement surgery scheduled the following week and needed the steps done before my procedure.
Eisner62
JAE
Tennessee
Getting ready to install my steps tomorrow if the weather is clear. Any harm in unplugging the factory can wire plug for a little better access for the post-taps?
capn00
Yardley, PA
None at all, if you don't unplug it, I don't see how it would be physically possible. I am pretty sure the instructions show it unplugged as well. Just take your time, that is by far the hardest part of the entire installation. Patience is key as these taps are tiny...
Just make sure the factory can wire appears to go through the center of the positap, and it is screwed back on straight and not at a slight angle. Figured that out the hard way.
Good luck. They are great once installed and worth the effort.
capn00
Yardley, PA
Alright, got them corrected!
Amp Research Tech Support sent me a troubleshooting document, and at first it appears to just be a re-stated summary of the torque sequence (which I did again to no avail), but then they highlighted a comment at the very bottom of the document I had missed that stated:
- If you are still experiencing issues move to the next step and perform the adjustment below
- If everything is tight deploy the step, loosen the rear mounting bolts, at the body. Remove the bolts and break free the step from the front linkage. Lift the board off the lower mount 2". While holding the board up, tighten the body mounts.. Reinstall board to front lower mount and retest.
Upon following that sequence, the board now retracts into the correct alignment position. I wish I would have seen that statement before I went through the trouble of removing the motor and redoing the tourque sequence first, but at least I knew there was no binding. This would have corrected the issue though, hopefully it helps someone else here as well.
I ended up paying $1,442 all in by finding the best deal I could during Black Friday, so even though I had a couple extra days of troubleshooting, I am very happy with the purchase.
Here is the troubleshooting file they sent me. They sent it as a screenshot and it was very small in my email application which contributed to me overlooking the important part at the bottom, but eventually it worked out.
Ford Bronco DIY  AMP Research PowerStep installation tips. Screen Shot 2023-12-05 at 7.00.36 AM
