Display current gear on the dash?
Skernie
So Cal
2013 F150, 2023 Bronco
My F150 will display what gear I am in on the dash, is there a setting on the Bronco that would allow you to turn this feature on?
Thanks
AZ_Liberty
2007 Expedition
Stick shift always shows you which gear you are in.
Automatic inexplicably does not.
F-150 does it, but not Bronco for no reason whatsoever other than Ford does things for no reason.
Skernie
Skernie
So Cal
Thanks for the replies.
MyATV
ATL
No, but it'll tell you other useful information... like when you're parked on a 1° incline at the mall.:rolleyes:
Scott R Nelson
Meridian, ID
DVO50
Darin
F350 Diesel, GMC 1500 3.0 Diesel
My 2023 2.7 A/T does. Sorry yours doesn't.
Ninjak
Miami
As others said, tap the manual button, and it will show you your current gear, briefly, at the top of the tac.
Skernie
Skernie
So Cal
I’m sure OP clearly means have the gear displayed at all times in drive. It’s not possible.
Yes that is what I was referring to was having the current gear displayed at all times.
I just thought of something, since it does show for a moment when you hit the button, then there might be a way for it to be changed using Forscan.
Thanks everyone for your replies.
Ducati1098
Unfortunately no. I’ve changed everything in forscan related to gear or display and haven’t been able to get it to work.
Docindahouze
Doc
Cumming, GA
Ford Bronco
Thanks
As a former f150 and super duty owner I miss the display that shows which gear you are in. I noticed it was missing right away. We can still downshift though when I’m in Drive which is nice. I use it sometimes.
Canoehead26
Dryden, Ontario, Canada
2023 Ford Bronco
My 2023 Bronco 2.3 litre Outer Banks will momentarily show the current gear when I press the manual shift button. It then goes off.
Like others have stated, my 2018 F-150 Lariat indicated what 0-10 gear range I was always in on the left side of the instrument panel. This was always displayed but you could turn it on and off by pressing the selector button.
I did like that feature on my F-150 and perhaps something Ford should consider for the Bronco.
Skernie
Skernie
So Cal
It's a small thing, but I do like to see at what speed my truck shifts. I am glad to see I am not the only one that likes that feature.
