Display current gear on the dash?
BadlandsA51
Craig
Kansas
23 Badlands, Sasquatch, Lux Pkg, 72 Ranchero GT
My 2023 2.7 A/T does. Sorry yours doesn't.
My 20233 Badlands doesn’t. Is that something you can turn on? I really like knowing what gear I’m in.
Skernie
Skernie
So Cal
2013 F150, 2023 Bronco
From what everyone is saying, it is not something that can be turned on, not even with Forscan. I agree with you, I also like knowing what gear I am in.
Toffs
Atlanta, Georgia
2011 Ford Raptor
The Raptor displays the gear at all times. Although it is a different instrument cluster, I would think that forscan would address it for the digital side of the cluster?
Skernie
Skernie
So Cal
Ducati1098 in post 12 said he has tried Forscan with no luck.
BadlandsA51
Craig
Kansas
You know, after seeing the cluster in a Raptor, it kinda ruined me for the cluster in my Badlands. That’s really the only thing I can say I don’t like about the Badlands so far. The cluster is pretty weak.
Az_Squatch_Bronco
Shawn
Tucson
Bronco Badlands w/ sasquatch pkg - Carbonized Grey
Can Forscan change your model? Maybe change it make your Bronco think its a Raptor and unlock the Raptor cluster? Seems the clusters are all the same its just programming depending on your trim level.
T800
Rick
Riverside, CA
OBX SAS Avalanche Gray
Assuming this still isn't an option in 2026? Seems like an easy thing to add.
Maybe because the 10 speed doesn't always know what gear it's in? :cwl:
VirginiaHeritage
Frank
‘25 Bronco HE
The auto only tells you in manual shift mode. I guess they figure we don’t need to know otherwise.
joes bronco
Gordon
post falls Idaho
2021 bronco 2017 f150
scan gauge ultra will show what gear your in plus a whole lot more
SHANUT
Craig
Hermann, MO
My F150 will display what gear I am in on the dash, is there a setting on the Bronco that would allow you to turn this feature on?
Thanks
Not like on the F150
