Disabled Camera in Sand mode - Software update to blame?
Natai
Sean
Sacramento
Nissan Sentra, Mercedes GLC
So I'm currently at the Northwest Bronco Roundup in Florence, OR. We had just under 150 Broncos meet up on the beach this evening, and a couple of use noticed a new issue:
Our cameras are no longer usable in motion in Sand mode.
Previously, we could use our cameras while in motion, as long as we were in any of the off-road modes. And we can still use cameras in Baja mode. But if we put it in Sand mode, the cameras are not available while in motion (over the usual 5-10 mph.
At least 3 of us noticed this issue, despite using our cameras while driving in Sand mode in the past. All of us that noticed the change were driving 2022s. We spoke with a couple people in 2023s, and they can use their cameras in Sand without issue.
Since this was working before, we're thinking this was caused by a software update.
Anyone else have this issue?
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Did you all check your versions of software? Might be a good idea to see if you all got the same updates.
lakesinai
Charleston SC
What you describe is accurate for my 2021 non-sas OBX. Sand: no camera in motion after 5mph. If you change to Mud/Ruts, you will have camera while in motion. You can use mud/ruts on the beach. Another work around might be to put in sand mode and switch to low range, camera might work then.
Natai
Natai
Sean
Sacramento
We didn't get a change to check software versions. (Had limited time before we had to move due to incoming tide.)
Definitely felt like we were on to something with a difference between 22 and 23 models. And the fact that at least a couple of us with 22s remember using cameras in Sand mode last year.
