Differential Cover Solution to Brake Line Support
Elevator Man
Dan
2016 Mercedes GLE, 2021 Badlands
If you've ever gone to replace the stock differential cover with an aftermarket one, you may find a problem with attaching the brake line support to the aftermarket cover. The stock cover uses two bolts with studs on them to hold a plastic clip that supports the brake line. See images below of a removed stud and the stock diff. cover with the stud removed. One side of the stud holds on the diff cover and the other is used for attaching the plastic clip that supports the brake line.
Ford Bronco Differential Cover Solution to Brake Line Support 1696018259619
Ford Bronco Differential Cover Solution to Brake Line Support 1696018282121
A lot of aftermarket diff. covers use recessed allen bolts to protect the bolt heads from getting damages on rocks. This presents a problem for supporting the brake line because the stock studs won't fit into the aftermarket covers so there isn't anything for the brake line supports to clip onto. If you don't want to leave the brake line unsupported, there isn't an obvious way to use an aftermarket cover with recessed allen bolts and support the brake line.
The solution I decided on was to buy some bolts from the local hardware store and weld them to the diff. cover to make my own studs. See images below. Hopefully this helps you out if you run into the same situation.
Ford Bronco Differential Cover Solution to Brake Line Support 1696018891357
Ford Bronco Differential Cover Solution to Brake Line Support 1696018909692
Ford Bronco Differential Cover Solution to Brake Line Support 1696018933025
Ford Bronco Differential Cover Solution to Brake Line Support 1696018977186
swamp2
Cool. No concern about the welding distorting the cover?
Elevator Man
Elevator Man
Dan
Wouldn’t welding in those areas introduce a sealing weakness?
No, the cover is very very thick, it's not sheet metal. I'd guess it's like 1/2" thick without measuring. Also, it's pretty much only a few tack welds so you aren't putting much heat into the part.
Elevator Man
Elevator Man
Dan
Fmuguira
Frank
Idaho
Jeep TJ
Hopefully the cover manufacturers take note and modify their full production/design to incorporate the OEM hardware and/or use newly manufactured hardware that takes the brake line OEM mounting into consideration !!
Doesn’t seem like a big “ask” when a guys forking out 200-300 clams ……
CarbonSteel
Colorado Springs
2023 Carbonized Gray
I just added a few small washers for my ARB.
Is that a drain plug at the bottom right of the cover? If so, is it magnetic?
PWillette
Parrie
Maine
I have the ARB and can confirm that is a drain plug and it has a magnet.
Elevator Man
Elevator Man
Dan
CarbonSteel
Colorado Springs
This would work for holding the brake line, but since the stud has no nut on it, the stud wouldn't do anything to secure the housing so it wouldn't work.
It would--install the stud, put a nut to hold the cover, slip the plastic part over the remaining stud and put a lock nut to hold the plastic part
Elevator Man
Elevator Man
Dan
That sounds like a reasonable solution. You don't need anything to hold the plastic brake line holder. It just slips over the stud and uses compression to hold on. I like your solution though, maybe it'll help someone.
CarbonSteel
Colorado Springs
After pulling my cover, I am not sure how long those compression "tabs" inside will last and in typical OEM fashion you have to buy the whole brake line to get the clips as they are not sold separately.
I am looking at finding a better solution to hold the brake line because (at least for the short term), I plan to pull the cover a number of times to change the fluid.
