Difference between Bronco 4 cylinder and Mustang
stokesrl
Bobby
tennessee
2023 outer banks
I have a 2023 outer banks 4 cylinder. I’m sure this has been covered but I didn’t find it. It seems like the mustang 2.3 has a bit more power than the Bronco. The question is - what is the difference and can the Bronco be retro fitted to be equivalent? Thanks guys
HalfmuleFarmer
Thomas
2025 Badlands
Ducati1098
Pinto73
david
Jupiter Fl
2023 Bronco 2door big bend
I heard the the bronco 2.3 had different oil baffles for inclines, it was on you tube. other than that not much different. the question is it the same 2.3 that was in the focus rs . it put out 350HP.
Ducati1098
Completely different engine if you're referring to the new 2.3
The Focus RS never had port injection.
TK 4210
William
Austin Texas
1985 suburban, 1990 Suburban
the engine is a much cleaner installation.
heavyD
Calgary, Alberta
2025 Badlands 2-Door
Different tuning, transmissions, vehicle weights, and aerodynamics can lead to drastically different results out of the same engine hardware.
