Diff drop recommendation
jsoa
Jose
Delaware
2024 Bronco 4dr
I have spent a few hours a day on installing the dobinsons front differential lowering kit on my 2024 ford bronco badlands and its been a complete bitch to get it in and aligned and I still don't know if its correct ! the video instructions I have found suck and then I tried to install the dobinson front sway bar disconnect lowering kit that that damn thing isn't correct !
having both of them, and having removed and readded them a couple times my best suggestion for the diff drop is to mount the passenger side first then things are better aligned. As for the sway bar relocation kit, I didn't have any issues with it other than my skid plates needing a spacer to clear it
Goods7506
Williston
2024 ford Bronco Badlands
I am still playing with this, one one good video I have seen showed a smaller bracket that goes on the rear up near the pivot point that I don't have which would explain the two gold bolts I have left over as I did finally get everything in but it still doesn't look right but now seeing that ? then tonight I went a different route to break my mind and tried the sway bar disconnect and I did it the way the directions way and the bolts don't line up, its like the instructions asked me to put the flat bolt holes towards the front and I put the flush mount bolts in on both sides and raised the sway bar up and not the other bolt holes don't line up so I don't know if I need to turn it around or what .. nothing dobinson is going on correctly
jsoa
Jose
Delaware
2024 Bronco 4dr
dobinson diff drop doesn't have a bracket for the pivot point, perhaps you are looking at https://www.brokeninnovation.com/broncoproducts/p/complete-assembly
For the sway bar relocation your sway bar should be further to the rear when mounted, and the recessed holes should be used on the stock location (not sure if that helps)
