Debating on 2.3 vs 2.7 engine?
Tricky Mike
21 Bronco
If you are a serious off-roader, Sasquatch is a no-brainer, and you'd never question the choice.
There's a point of serious off-roading where the pendulum swings back too. By the time I'm done every single component that Sasquatch includes will have been upgraded. I should have started with a plain base. 😆
MEAT_GOD
Kuwait
22 Ford Bronco 2dr, 15 Maserati Quattroporte
The 2.7 has more downsides than upsides, and even the upsides aren't all that important (sound, I guess) so I'd honestly recommend you stick to the 2.3.
MEAT_GOD
Kuwait
Nope, lockers and gear ratios. Can't really find a solution for that on the 3.73 gearing that doesn't cost more than the sas package.
Tricky Mike
21 Bronco
Tossing out my 4.70 axles to get complete 5.38 axles. Yes, they are more than the initial price of Sasquach but at least I wouldn't be paying twice.
Aonarch
Jack Hoff
MT
‘23 Bronco OBX 2DR Lux 2.7, ‘24 V60 Polestar
Yeah starting with a Base would be good.
I actually calculated the cost of starting Sasquatch vs not, keeping in mind reselling stock Sasquatch bits.
Mine is not Sasquatch. I have Bilstein 6100s, rear LSD, Anti Rock sway bar, etc etc.
MEAT_GOD
Kuwait
Honestly, if you're going for 5.38 then you're a little bit more psychotic than most people. Going above 3.73's more of a necessity for a lot of people, and so are the lockers, if that makes sense.
Bronco Lane
Dean
Nebraska
2024 Bronco
I got my 2.3 for reasons, the (expected) slightly better MPG and I simply do not like plastic pans. I like the 2.3, but just like the 2.7 it sounds silly.
Plastic oil pan and the wet belt driving the oil pump made me get the 2.3
userdude
Jared
Denton, TX
2023 2dr Badsquatch
If you were willing to order the 2.3L, I don't think you'll be disappointed. If your wife made you get the 2.3L and you don't want to park a 2.3L next to your hemi-engine fill-in-the-blank, you may want a Raptor. If you want to add stuff to the engine, you can upgrade it more readily with the 2.7L.
Bronco Lane
Dean
Nebraska
2024 Bronco
Definite bonuses. It was the 2.7 cam phasers for me, as a seasoned Ford fan I knew they were going to be an issue.
People get wrapped up in numbers. My first new pickup was a 1980 F150 351 V8. I don't think it made 150hp and 250 foot pounds of torque. The 2.3 makes more than that , I have yet to feel under powered in my 2dr Bronco
zombie
New Brunswick, Canada
'21 Bronco '22 Mustang GT PP 06 Viper SRT10
I've had both. The 2.7 is far superior in every way. And no fuel dilution.
Not every way, since:
a) can't get a stick with the 2.7 (may not matter to you, but matters to some of us)
b) there's a pretty significant number of 2.7 failures and not nearly as many 2.3 failures
malpais
Some old Honda
I went with the 2.7. The 2.3 is a fine engine and gearing makes it move this massive brick quite well. My only real criticism of it is that it doesn't have port injection, so the valves and intakes will get foul after a while (purportedly this is going to change).
2023bronco
location
vehicles
There's no replacement for displacement.
