Damage while using winch on improperly installed Rough Country High Mount
Status
Not open for further replies.
GreyZ
Gulf South Louisiana
Who did the lasering and bending? I am looking to get some other stuff done and the shops I have used in the past never come out looking that nice.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
PM'd you.
Brad
Washington
Bronco Mustang Maverick F250
The prototypes are welded up and ready to test fit tomorrow. I'd love to have a first run to sell at the Stampede in 2 weeks but it's going to be tight.
What is the price point? I am looking to add the RC high mount or something of similar design. I am going to be at the stampede hopefully with.my Bronco if not I'll be in the Mustang
Tricky Dick
Dick
PNW
I have yet to crunch all the numbers but probably in the 200-250 range. Yes, it'll be the most expensive solution, but I also want it to be the best.
Brad
Washington
Does that include at show instalation 😉🤪
Tricky Dick
Dick
PNW
Bearcat1
Travis
2017 Expedition Limited, 2006 BMW 330xi
I have my RC High mount currently on a Capable bumper. Only difference seems to be the Capable does not need the washer shims in front vs the modular. I can't see any reason your solution would not work with the Capable bumper, thoughts?
Tricky Dick
Dick
PNW
It should work with all the OEM bumpers and a lot of aftermarket.
RC Bronco
Kansas
I’ll be in for a set when they go live
Brad
Washington
I guess this needs to be said, my wife will NOT be at the show so no explanation will be required if you have them there and ready.... just sayin.
Tricky Dick
Dick
PNW
So good news, my frame horns didn't move, although they sure tried. The unmodified LOD brackets were hanging on for dear life but the modified ones are straight as an arrow and showed no sign of bolt pull through.
I'm done with the RC mount and the mod bumper. I'm deleting the intercooler louvers and tucking the winch up in there and building a bumper around it. The Warn fits between the horns with 1/2" to spare. Non-ACC FTW.
Ford Bronco Damage while using winch on improperly installed Rough Country High Mount PXL_20230513_022057141
Ford Bronco Damage while using winch on improperly installed Rough Country High Mount PXL_20230513_020937006
Ford Bronco Damage while using winch on improperly installed Rough Country High Mount PXL_20230513_020843457
MillerAndCheeto
Robin
Calgary, AB
2 Door Cyber Orange Wildtrak Sasquatch
When you say "unmodified" LOD brackets, did you have 1 with a gusset welded on and 1 just stock?
Thanks again for all these updates.
Deleted User 5719102
Who's
On a Lake
22 2dr
Dude you need a manicure LOL:) :) :)
Tricky Dick
Dick
PNW
The inner set - that the RC mount ride on - are gusseted and dimple stand off spacers welded on. The outer plate with the single bolt are unmodified.
Status
