- First Name
- kevin
- Joined
- Jul 27, 2020
- Threads
- 12
- Messages
- 1,371
- Reaction score
- 1,777
- Location
- Ontario & Kentucky
- Vehicle(s)
- VW GTI VW EOS GMC Envoy Badlands Bronco
- Your Bronco Model
- Badlands
I see where you were asking about the angle now. I will check the cad again. Now even though it looks like the tip of the horn may have pulled up, that might be a nothing burger as far as structural goes. Take a pic from the front and focus on where the two rails overlap. Check the welds top and bottom to look for cracks.Well naturally I forgot my angle finder at work, but it's hardly needed to see what's going on. The tops of the plates are obviously pulled out and the paint is cracking.
I saw probably no big deal cuz ;
1) the bumper mount plate has a lot of weld and kept the horn from separating too far back - if it separated at all.
2) even if it did separate a skooch the tip of the horn really has no load on it. If the welds are good I would not worry about any separation as long as it is in front of the bumper plate(again take some pics, both sides) Check behind the plate to see if any of the ecoat(paint) has bubbled / cracked. Check the bumper mount plate with a straight edge - see if the surface is still flat. Flat is good
3) the only other thing I see worth checking looking at those pics is the angle of the bumper mount plate relative to the frame. Your pics show the plates are slightly angled down. I need to check but this might be normal.
4) where the paint has cracked, I can give you the name of the best kind of paint to use. Simply brush / grind of crappy paint and reapply. This is not a big deal but is worth cleaning up while its apart. Touchups like this happen all the time for a lot of reasons.
give me some time as I need to log into work to check - but even though it looks the tip has moved, it might just be cosmetic. Check both sides to see if anything looks different from LH to RH side. The biggest thing is to check the welds / and or steel splits or "bumps" where it should be flat.
I am curious though if the tips pulled up, how are things attached to cause that. Did something rotate(think single bolt pivot point) and catch the tips on the way up?
