Damage while using winch on improperly installed Rough Country High Mount
Status
Not open for further replies.
Murph914
Franklin, MA
2008 F-350 reg cab srw v10 manual
As others have said the Matt’s Offroad video of the DV8 rig was sobering. Distance from the rail to load point will be a major concern.
Dusty
Mentone, CA
70, 71 & '21 Broncos
Tricky Dick
Dick
PNW
www.TD-Distributing.com
I just haven't seen an aftermarket bumper I really liked yet.
It would be the Lobo winch bumper for me but I can't justify nearly 2k.
Deleted User 5719102
Who's
On a Lake
22 2dr
I don't think it would matter but maybe?
It miiight be just the plates. I won't know until it's apart.
Vivid Racing has the LoD brackets in stock, I just ordered a set.
I would tend to think the mounting brackets got stretched forward at top and pushed back at bottom. Or you tore the top welds at top. Unless you come up with a spreader bracket (frame rail to frame rail) you will continually have this happen. Only other real fix would be to gusset the top and bottom of mounting plates to strengthen them or completely fabricate the mounts by boxing them in. Which would probably require longer mounting bolts.
BroncoAZ
Mitch
My winch just arrived, I’ll be choosing a mount soon. If the front frame horn plates are the weak point I would expect it doesn’t much matter if a mount on the mod bumper or a full bumper replacement. In addition to the LOD brackets it may require some additional triangulation to prevent the bend.
EL in NH
Ernie
New Hampshire USA
2dr Basesquatch, 2005 HD springer,2010 sporty
I don't think it would matter but maybe? I might have only bent that inner ear.
There used to be a blurb on their web site stating something to the effect those reinforcement brackets only fit their bumpers..I don't see it now so maybe I imagined it(shrug)
I found it.. however they dont say only for the LoD bumpers..well u can read it
Ford Bronco Damage while using winch on improperly installed Rough Country High Mount Screenshot 2023-04-10 204506
Tricky Dick
Dick
PNW
I would tend to think the mounting brackets got stretched forward at top and pushed back at bottom. Or you tore the top welds at top. Unless you come up with a spreader bracket (frame rail to frame rail) you will continually have this happen. Only other real fix would be to gusset the top and bottom of mounting plates to strengthen them or completely fabricate the mounts by boxing them in. With would probably require longer mounting bolts.
The LoD brackets will certainly help with the plates but if I'm in there I might as well keep adding steel.
Tricky Dick
Dick
PNW
Hmm. Well anything will fit with a grinder and welder.
Who's
On a Lake
22 2dr
If it were me with this problem, I would discard the factory mounting plates, fabricate some fully boxed in 1/4" steel plates that would slide onto the frame horn stock location and fully weld in place front and back.
Who's
On a Lake
22 2dr
The LoD brackets will certainly help with the plates but if I'm in there I might as well keep added steel.
Triangulate each corner with a fully welded in gusset.
Tricky Dick
Dick
PNW
That would be solid. I think I'm going to bolt and stitch weld the LoD brackets to the frame as well as gusset the bend on them.
Who's
On a Lake
22 2dr
You can never really over do strengthening, (Well I guess you could). But gussets are your friend in these moments. Do you have a picture of these LOD brackets your speaking of? Never seen them or heard of them. Before I retired from the military, I would always go over to the engineering shop and fabricate my own stuff.
Status
