Creative place to mount a single ARB air compressor?
B Miller
Sherwood, OR
Hello Members,
Has anyone found a creative place to mount a single ARB air compressor? I have this one removed from the box:
Ford Bronco Creative place to mount a single ARB air compressor? Screenshot (69)
Thank you!
j_marinelli
Spring Branch, TX.
B Miller
B Miller
Sherwood, OR
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
I've been looking at this one, but cant seem to find where the hose coupler goes? Can you send a photo of the coupler?
The coupler stays on the compressor.. Here is a single compressor installed on our KR Off-Road mount. We left the caps on but the coupler will actually attach to the silver manifold cylinder as shown in your box.
Ford Bronco Creative place to mount a single ARB air compressor? 8
Then for a switch we recommend using our plate (which also allows you to mount the coupler to the switch plate as well):
https://www.4x4truckleds.com/kr-off...-coupler-switch-bracket-for-2021-ford-bronco/
Ford Bronco Creative place to mount a single ARB air compressor? 1669217398745
contented
Karl
Central Fl
BMW M2 Competition
Fwiw, I’d stay away from unique, confined areas and put it under the hood where you don’t have to worry about overheating. Although mine’s a twin, concept is the same.
Ford Bronco Creative place to mount a single ARB air compressor? 06E546C9-36F9-49B6-B9BA-8DF9CACCB82F
Ford Bronco Creative place to mount a single ARB air compressor? 14CC4764-0538-44E3-98FC-FF4F559BF36C
Mibuckeye
Grass Lake, MI
2021 Ranger Tremor
Saw one mounted inside the tailgate but cant find the link again. Anyone know where I can find this again? It wasn't in the spare, it was accessible from the inside.
SwampCactus
2022 4 Door Cactus Grey Badlands Sasquatch
Go under the hood. It's just wasted space otherwise. All the ones in the interior that space could be better used for other gear and a waste to put the compressor there.
JohnnyBoots
Greensboro, NC
Jeep XJ, BMW Z4, Mini Clubman JCW
I think it will fit in the passenger rear quarter panel, I fit a large inverter in there but I don't have a sub. I'd also want some added airflow for that location.
Ford Bronco Creative place to mount a single ARB air compressor? 4c225572-894e-4b1e-8547-431d00fe7cc7-jpeg
  • Like
Reactions: cbs
OddBall88
Joseph
Ford Bronco
American adventure labs makes a mount for in the hump of the tailgate.
KT_bronco
Jon
So-CAL
Transit Connect Cargo
Hi Brian, how did this end up? I have the same compressor in a box and trying to figure out if it has all the components necessary to just remove from box and install. Did you have to get additional splitters, hoses or wires?
B Miller
B Miller
Sherwood, OR
This didn't go well at all. It was a long time ago, but for whatever reason I ended up just getting the correct one and mounting under the hood. Another thing to note, I'd go with a dual compressor. The single I have takes forever to top off a tire from 25 up to 38 psi. Hope this helps!
KT_bronco
Jon
So-CAL
Appreciate the follow up, I was hoping to save a few bucks as I’m sure you were, but looks like I gotta get a double.
Doug_life
Oregon
23 wt, 78 bronco
I contemplated mounting it in an ammo can and bolting that to the frame where the stock exhaust was (I have aftermarket exhaust)
It was a lot more work than just buying and using the underwood mounts.
