Crease above glove box
Dan-O
Dan
Fountain Hills, AZ
FYI….be careful of putting graphics on the area above glove box…..if an accident should happen and airbag cannot deploy properly and somebody gets hurt because of that there could be some unwanted liability. Just sayin!!! On the other hand, dealer should not give any problem with warranty replacement of warranty those cracked areas under 36,000
The creases are from intentional weak spots in the plastic for the air bags to deploy through
Now, it’s not intentional that they bleed through and are visible on the passenger side. Ideally they shouldn’t be noticeable from the people side, but if you look at the back side that’s where the plastic is designed to burst open to let the airbag out.
YMMV getting a dealer to replace under warranty.
