Crash Bar End Caps?
BroncocnorB
Paul
Clearwater Beach
1965 Cobra,
Anyone come up with a cover, cap, slip-over thingy for the open ends of the crash bars to prevent debris or water from getting in there and potentially rusting, etc?
You can probably find a furniture leg end cap at home depot. That’s where I’m gonna look - or Amazon.
Drex
Jake
capping the one end will just make is more likely to trap moisture inside it and rust it faster. If Ford ever decides to make me a Bronco, I will just leave it, if it rusts out in 7 years, I will just buy another set and bolt them on.
BudgetBronco
Tim
Pittsburgh, PA
www.youtube.com
I found some caps that work well. The front fits right in, the rear requires a little bit of trimming because the bar is not perfectly square. Full video below but here are links to the products on Amazon:
Rear-most crash bar caps: https://amzn.to/31doDCX
Fore-most crash bar caps: https://amzn.to/3eEbBS3
buzpro
Binky
Tacoma
those things don't tend to stay on ... thinking about welding a cap on them and seal 'em shut on the end
BroncocnorB
Paul
Clearwater Beach
1965 Cobra,
Yeah it’s weird that they’re open. Why?
Headsong
BudgetBronco
Tim
Pittsburgh, PA
www.youtube.com
Are they open on the back, too? Would be a moisture and rust trap if so.
The rear-most bar is definitely open on the other end, and also slopes down that direction so I really don't think trapped moisture is an issue.
The front-most bar is a litter harder to tell but I think it also opens up on the other side.
Welding + grinding + painting is a good option too. If you are doing hard core off road wheeling that is probably better.
Headsong
So you'll need to cap both ends....
BudgetBronco
Tim
Pittsburgh, PA
www.youtube.com
I don't see the need to make that thing completely water-right. It IS coated on the inside. How is any different that other components, like the frame members for example?
Headsong
Good point. 'cuz someone brought it up? Lol
2021 Bronco on order
Tricky Dick
Dick
PNW
www.TD-Distributing.com
BudgetBronco
Tim
Pittsburgh, PA
www.youtube.com
