Conversion--Capable to Modular: Parking Sensors & Wiring Harness
braddavis2017
Bradley
Breinigsville, PA
Ford Bronco
krman
Stroppe
Tony
Cincinnati. Ohio
25 Stroppe Bronco , 68.5 CJ FB Mustang FB, 2025 CC F250 KR Tremor
Stroppe
Question for Squatched : If I understand your last reply correctly?
I am swapping from a "capable " bumper with parking sensors to a "modular" bumper with parking sensors. I can swap my factory rear outer sensors with factory front "capable" sensors to gain the 90 degree clearance needed. My used Modular came with the sensor holders so no mod needed there and the factory capable wiring harness will fit without issue?
Does that sound correct?
Thanks
Warner76
Ryan
Pittsburgh
2023 Bronco Wildtrak
I know this is a year old but did you have any luck using the original wiring harness from the modular bumper? I’m in the same situation but can not get it to work. Even with the FDRS update, I keep getting a park aid fault. I’m ready to just use the capable bumper harness but didn’t feel like tearing both bumpers apart.
CarbonSteel
CarbonSteel
Colorado Springs
2023 Carbonized Gray
Sad to say, I am just now getting around to prepping the mod bumper for installation. I have all of the parts and the tow hooks are out being powder coated and the bumper is at the paint and body shop being repainted.
I should have an update here in a few weeks.
Warner76
Ryan
Pittsburgh
I appreciate the update. I messed around with it today. You can use the original modular wiring harness when you swap but no matter what I did my Bronco (originally with a capable Bronco) would not acknowledge the sensors from the modular bumper. Not sure if the park assist module can be updated to accept the new sensors but I couldn’t figure out anything in forscan or see where anyone did it before.
